Author Topic: Lowering a Blazer  (Read 30931 times)
Offline slammed79
  • Thou shalt not drive stock
Lowering a Blazer
« on: January 29, 2011, 12:59:07 pm »
I've lowered more a pretty fair amount of our trucks in the past, and I've got a good cache of parts for introducing them to mother earth, but I've never done a blazer or a suburban.
As it stands I'm looking at a 79 2wd Blazer and a 73 Suburban, one of the two is gonna be my next squarebody and daily driver.
My question is this: If I put the flip kit I have on either of these, will I need to cut the floor to clearance the 12 bolt?
Praise the lowered
Re: Lowering a Blazer
« Reply #1 on: January 31, 2011, 09:39:20 pm »
want have to cut the floor, but you will HAVE to run a C-notch.
Offline slammed79
« Reply #2 on: January 31, 2011, 11:51:02 pm »
Already planned for that, thanks Capt!
Praise the lowered
Offline N2TRUX
« Reply #3 on: February 05, 2011, 08:09:37 am »
One thing you should be awarpe of is the gas filler hose on the Blazer. If you use a lowering shackle it will need to be modified. The longer shackle will not clear.
Offline slammed79
« Reply #4 on: February 05, 2011, 11:16:08 am »
Im planning on just the flip and c-notch. This will tide me over until bags.
Praise the lowered
Offline Low73
« Reply #5 on: April 17, 2011, 12:28:27 am »
sorry to hijack and drag out an old post but I have a burb and am wanting to do a flip on so I could use some help. How small of a c-notch would you use or can you give me some ideas on how to do it so it fits under the floor.  I have heard of people getting a thick 5-6 inch pipe cutting it in half and welding it for a notch but I have also heard of alot of people frowning on doing this.
Thanks
« Reply #6 on: April 17, 2011, 07:38:42 am »
If you can weld, the pipe is fine. Depending on the condition of the springs and the travel you may not even need to notch it. Mock it up and check. I've flipped the axle and used smaller bump stops without a problem.
« Reply #7 on: April 17, 2011, 12:40:57 pm »
Quote
I have been dropping these for about 25 years.  Up until now I have yet to buy an aftermarket C-notch.  A good welder can put it in fine.  I still have a truck I dropped back in 1989 and it is perfectly fine.
It is in the 73-87chevytrucks.com thread stickied in the Ride section: (infact on the first page, both of those have a fabbed notch.)
Offline 73k5
« Reply #8 on: June 06, 2011, 07:44:52 pm »
My old burban had a Big Notch
Offline slammed79
« Reply #9 on: June 06, 2011, 08:51:13 pm »
Got any pics of that burb goin together? I'd love to see the creation!
Praise the lowered
Offline 73k5
« Reply #10 on: June 07, 2011, 10:34:03 am »
Lost all the build pics in katrina......  Only had a few in my photobucket left
Offline 82BlazerMan
    • Blazer pics
« Reply #11 on: August 24, 2011, 12:13:34 pm »
Can this be done without removing the cab?  I'm pretty sure my cab and bed are one piece.
1982 Blazer 2WD
305ci
700R4
« Reply #12 on: August 24, 2011, 01:35:54 pm »
putting in a notch?  Who's is it?  bolt-in?
Offline 82BlazerMan
    • Blazer pics
« Reply #13 on: August 24, 2011, 07:59:28 pm »
It's mine.  I'm talking about the typical kits that come with the notch hardware that bolts in.  It does'nt look like you could slide the brace in over the frame without taking off the cab.  Truck beds are easy to remove, but a Blazer cab and rear area are all one piece.
1982 Blazer 2WD
305ci
700R4
« Reply #14 on: August 24, 2011, 08:34:44 pm »
As in who's kit, not who's Blazer...
If it requires through bolting you can losen one side of the body bushings and jack the body up install one side and then do the opposite on the other side.
