Author Topic: turbo  (Read 16709 times)
Offline arcountryboy
turbo
« on: February 03, 2011, 06:21:58 am »
I was looking through Ebay last night searching for any deal and noticed the large amount of turbos on there for 350's.  I have ran a supercharger once but I have never ran, nor seen to my knowledge a turbo on a 350 pickup.  Ran one on a honda once though.  I wouldnt put an Ebay turbo on my truck, but I was curious what you figure the gain would be with one?  I know on my honda accord 4 banger it made a huge difference, but it took it a minute to spool up.
Re: turbo
« Reply #1 on: February 03, 2011, 08:47:53 am »
     Do a search on here, there are a couple threads on here about turbo installs.  Capt even has one, though not sure if he finished or not.
Re: turbo
« Reply #2 on: February 03, 2011, 12:48:50 pm »
Neither are finished, work in progress right now.
With a properly sized turbo you will see no lag and huge increases in power.  100hp isn't out of the question on a SBC, but the motor itself needs to be setup to handle extra forces if you plan to crank it above 5lbs of boost.
Offline 1979C20
  • Kyle Taulton.
Re: turbo
« Reply #3 on: February 04, 2011, 12:28:12 pm »
Ive heard of and seen 1 newer camaro(bubble body style, 90's i think?) Where they put 2 turbos, dual exhaust, above the rear axle and ported it back up to the intake and didnt need an intercooler! pretty smart. Also, if you do a blow through system you need to strengthen the internal parts of the carb, almost better to use a throttle body instead. And you could very easily destroy the rotating assembly with too much boost. Steel crank, forged pistons, strengthened carb, Proper sized turbo(s). Oil lines. An intercooler if you do manifold turbo(s). It takes a LOT of work. I wouldnt do it to any engine that has anything stock about it. I was looking into it during my build. It would be pretty sweet to do dual draw through turbos, like some of the quick :( bugs. Gives me chills just thinking about how beautiful the engine bay would look with 2 huge turbos staring at you when you pop the hood.
Re: turbo
« Reply #4 on: February 04, 2011, 12:47:51 pm »
We install those turbo kits, they were visioned and sold by STS of which I am a dealer.
They make great power.
Re: turbo
« Reply #5 on: February 04, 2011, 07:27:25 pm »
Quote
 ??? Huh?
Re: turbo
« Reply #6 on: February 04, 2011, 08:14:46 pm »
Quote
 ??? Huh?
There wasnt room in the engine compartment, so the turbos and wastegates were under the chasis towards the rear. It was on one of the powerblock shows.
1979-The reason they didnt use a intercooler was because of low boost, not because the turbos were so far back. That wouldnt matter.
Offline 1980c10
Re: turbo
« Reply #7 on: February 04, 2011, 08:58:10 pm »
I had a turbo on an audi a4 with about 12-15 lbs of boost it wasn't real fast off the line but it was a sling shot on the top end. a lot of fun to drive and you learn to keep your rpms up to keep it wound. say if your going to pass someone you'll down shift just a little earlier.
Offline 1979C20
  • Kyle Taulton.
Re: turbo
« Reply #8 on: February 05, 2011, 01:20:02 am »
Beastie, I though they didnt need an intetcooler because they didnt have the heat of the manifolds/engine to cool down.
Re: turbo
« Reply #9 on: February 05, 2011, 01:56:51 am »
Havent seen the episode for awhile.
Offline slammed79
  • Thou shalt not drive stock
Re: turbo
« Reply #10 on: February 05, 2011, 02:10:42 am »
I'd love to Turbo one of our trucks, I'm thinking twins, maybe the billet housing ones from Nelson super cars, they can be clocked for symmetry, cause if yer gonna spend the money, why not make it pretty too!
Praise the lowered
Offline Da67goatman
  • Burban
Re: turbo
« Reply #11 on: February 05, 2011, 03:06:28 pm »
Powerblock Trucks put a tailpipe turbo on their Lightning, real clean look.  Stacey David's Gearz also put tailpipe turbos on a C6 Corvette.  That would be the only way I would run one.
<Pitcrew>
Re: turbo
« Reply #12 on: February 09, 2011, 09:35:51 am »
The ones I sell are the same ones Powerblock put on the Lightning
Offline KY..Rob
Re: turbo
« Reply #13 on: February 09, 2011, 02:08:19 pm »
Offline ehjorten
Re: turbo
« Reply #14 on: February 09, 2011, 02:12:03 pm »
Turbo at the back of the exhaust is gonna be major lag and not nearly as efficient!  You lose a huge amount of the heat coming out of the exhaust ports and lag is directly proportional to the distance the turbos are from the ports.  Not saying it won't make boost, you will just be able to count it down with the minute hand on your watch! :D
-Erik-
