Author Topic: having a problem removing the front ball joint  (Read 41377 times)
Offline log1000
« on: February 04, 2011, 07:47:11 am »
if they are stuck in how to remove ball joints for a  k10  ??? 4 x4
k10 Custom deluxe don't how what year it is
this is how it is stuck
now the trucks brakes are sticking after we put in a new brake booster and the 3d gear drive is slipping what do i do to fix the brakes, and the 3d gear drive?  ???
« Last Edit: March 21, 2011, 07:29:02 am by log1000 »
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: having a problem removing the front ball joint
« Reply #1 on: February 04, 2011, 07:49:30 am »
4x4 or 2wd?  big diff.
http://www.delbridge.net/balljoints
Offline log1000
Offline thirsty
    • Suitor's Garage
« Reply #3 on: February 04, 2011, 08:41:27 am »
When you say stuck in do you mean stuck at the axle housing or stuck in the steering knuckle?
Stuck in the axle housing:Remove wheel, brakes, hub, bearings, rotor, tie rod, spindle, axle shaft, ball joint nuts, and smack axle housing were ball joints go in real hard with a big hammer.
Stuck in the steering knuckle:Take the knuckle to a garage and ask them to help you out with a ball joint tool. Or rent one if one is available.
Offline log1000
« Reply #4 on: February 04, 2011, 10:05:33 am »
i have tried using the ball joint tool but it didn't work
Offline Sartobuilt
« Reply #5 on: February 04, 2011, 10:35:46 am »
Did you remove the snap-rings? Sometimes they are buried in rust, grease and mud. I use a jack stand that is a round pipe, Flip the knuckle upside down so the upper joint fits into the tube to support the knuckle. Drive out the lower, then with a long punch or what I use is a 1/2 drive extension and socket drive out the upper. Reverse for installation. It helps to have some big sockets that fit over the shoulder of the balljoint.
I hope this helps.
Offline log1000
« Reply #6 on: February 14, 2011, 06:34:26 pm »
I hope this helps.
the ball joints on it are 20 years old
Offline jason d o
« Reply #7 on: February 14, 2011, 07:17:06 pm »
There are some good videos on this topic in you tube. One of the best ones ive seen is from farmboy. Just type in farmboy on the youtube website. I think it is under farmboy 30117 or something close to that.
« Reply #8 on: February 14, 2011, 08:12:27 pm »
I hope this helps.
Why didn't you answer his question?
« Reply #9 on: February 15, 2011, 03:47:54 am »
that axle is over 20. 31-35 years old the snap rings can be real hard to see with rust and dirt being all over
Offline Sartobuilt
« Reply #10 on: February 15, 2011, 12:12:57 pm »
Here is a link for the Dana axle Bill Of Material, http://www2.dana.com/expertforms/dedraw.aspx?drawing=00002370 . I am not sure what you are referring to as stuck? If you remove the 4 bolts for the top cap and then remove the spring and the plastic bushing. Then remove the lower bearing cap bolts. To remove the lower cap you will need to persuade it a little bit with a hammer. Tap the cab from the side to rotate it a little then you can tap it down to remove it. The knuckle will then fall right off.
I hope I have helped you now.
Offline Sartobuilt
« Reply #11 on: February 15, 2011, 12:37:32 pm »
Hey thanks for pointing that out. I guess I read it wrong.
I should have stayed out of it, but I took it as:  Why didn't you remove the snap rings?  answer:  The balljoints are twenty years old.  Did Log1000 remove the snap rings?  I don't know anything about this topic, I'm just reading it to learn a little something.  I just hate to see someone get upset over a misunderstanding.  It is none of my business, though.  You and Vile are big boys, you can work this out.
« Reply #12 on: February 15, 2011, 03:31:48 pm »
Not sure what I missed or what you wrote but from the sounds of it- it's probably a good thing.
Offline log1000
« Reply #13 on: February 15, 2011, 06:18:04 pm »
yes i did remove the snap rings but it is just the lower ball joint now that is stuck I'm thinking of using vinegar to loosen it
« Reply #14 on: February 15, 2011, 06:22:00 pm »
You're using a ball joint press right? PB blaster and a 3lb BFH is all you need. Once you have some good tension on it, strike the knuckle near the ball joint area sharply 2-3 times then continue with the press. It should pop right out.
