Author Topic: Not a truck but need help  (Read 16588 times)
Offline JRConnieK10
« on: February 11, 2011, 08:52:34 pm »
  Ok so we take the wife's car out last night for the first time in a while. Its kind of a fair weathered car. So the problem is it has no park lights, dash lights or brake lights. Head lights worked fine high and low beam and turn signals work. Its a 2000 Camaro 3.8 V6 automatic. Looking for some ideas of what the problem could be.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
Re: Not a truck but need help
« Reply #1 on: February 11, 2011, 08:54:18 pm »
Test the switch and make sure the fuses are good. If you did recent work on the car, check around those areas to see if a wire got cut or something.
« Reply #2 on: February 11, 2011, 08:58:59 pm »
Check Fuse #14 and see if it's open.
Offline JRConnieK10
« Reply #3 on: February 11, 2011, 09:24:10 pm »
#14 is the wiper/wash correct? It is good.
BUILT NOT BOUGHT
Offline screamin86
« Reply #4 on: February 11, 2011, 11:25:57 pm »
Check over on camarov6.com I had a 98 3.8 v6 camaro and had a similar issue but mine was the headlights themselves quit working but I had everything else workins and all my fuses were good then one day the gauges started jumping around and I heard a buzzing sound and smoke came outa the dash and I traded it in lol. I miss that car though. Anyway sorry I wasn't too helpful but you might wanna try one of the fbody forums like the one I posted it might be a little more helpfull.
86 ta:lm7 hot cam boltons
« Reply #5 on: February 11, 2011, 11:55:32 pm »
im with beastie on this one. check fuse then check out the switch
« Reply #6 on: February 12, 2011, 06:32:24 am »
Rear fuse panel.
Offline JRConnieK10
« Reply #7 on: February 12, 2011, 12:09:34 pm »
Rear fuse panel.
Ok sorry, I didn't now you meant under the hood. Anyway looking at the ones under the hood they are not numbered to where I can determine which is #14. I have the book that shows each panel and what each fuse and relay is but they aren't numbered.
BUILT NOT BOUGHT
« Reply #8 on: February 12, 2011, 12:35:48 pm »
Sorry JR I was looking at the wiring diagram on my phone, let me double check now that I'm at my computer
« Reply #9 on: February 12, 2011, 12:38:43 pm »
Does the 3rd brake light work?
« Reply #10 on: February 12, 2011, 12:41:22 pm »
Check fuse #5 20A fuse in the instrument panel fuse block. Make sure you check it for B+ on each side of the fuse with a test light. If OK check the headlight switch next.
Offline JRConnieK10
« Reply #11 on: February 12, 2011, 01:31:00 pm »
No the third brake light does not work.
BUILT NOT BOUGHT
Offline JRConnieK10
« Reply #12 on: February 12, 2011, 01:41:55 pm »
Ok no power to #5 20A fuse. The fuse is good but I replaced with a new one just to be sure and still no power.
BUILT NOT BOUGHT
« Reply #13 on: February 12, 2011, 01:59:07 pm »
That fuse should be hot at all times. You validated the test light works right? I'm going to go with you did.
If that's the case check the connections in the bus bar inside the i/p fuse box.
Offline JRConnieK10
« Reply #14 on: February 12, 2011, 02:11:08 pm »
Yes I double checked that I had a good connection the radio fuse was hot and lit the test light but that one wouldn't. Not to sound stupid but what do you mean the bus bar and i/p fuse box? Is that with out the fuse in? I did that too.
« Last Edit: February 12, 2011, 02:13:25 pm by JRConnieK10 »
BUILT NOT BOUGHT
