Author Topic: Front Cradle Torque Specs  (Read 8302 times)
Offline TxFiddler
« on: February 11, 2011, 10:38:35 pm »
I am putting the front cradle back on after getting back from powdercoat.  What are the torque specs of the bolts that fasten it to the frame?  All of my pics are too large at the moment.  I will figure a way to do a resize or an album fr all to see.
Many thanks to all,
Fidd
80 C10 2wd / 427 BigBlock / 700R4 / 3:42 Eaton Posi LSD / 770 cfm Holley Street Avenger / Doug's Headers / MSD ProBillet Distributor / Champion 3 row Radiator
Re: Front Cradle Torque Specs
« Reply #1 on: February 14, 2011, 05:58:48 pm »
"TIGHT"  I have never torqued them...
Offline thirsty
    • Suitor's Garage
« Reply #2 on: February 14, 2011, 06:21:22 pm »
Make sure the bolts are grade 8 too.
Offline eventhorizon66
« Reply #3 on: February 14, 2011, 07:02:18 pm »
Never done it, but I were in the same situation, I would just use these accepted max torque values as a guideline.
http://www.engineershandbook.com/Tables/torque.htm
'85 C10 SWB 350 700R4 TKO600
« Reply #4 on: February 15, 2011, 09:16:14 am »
I have them in a word or PDF document but I can't post it here.... Chris, Can you allow attachments such as .doc or .pdf?
Offline TxFiddler
« Reply #5 on: February 15, 2011, 02:17:22 pm »
Thanks everyone.  I was able to find what I needed.  Cradle to side rail is 65 ft/lbs and to bottom rail is 90 ft/lbs.  Just in case anyone else wanted to know.
« Reply #6 on: February 15, 2011, 03:29:42 pm »
You are correct. -Chris I can email you this if you want to make a tech page on it. It shows the whole front crossmember, hardware and torque specs.
« Reply #7 on: February 15, 2011, 06:05:43 pm »
Offline TxFiddler
« Reply #8 on: February 16, 2011, 07:47:39 am »
Good ol' Chuck is where I found em.  Such alot of good info.
« Reply #9 on: February 16, 2011, 06:10:59 pm »
send them to me Vile and I will post them.
