Author Topic: New starter in truck, with jumpers on battery, no start.  (Read 5287 times)
Offline SSgt Smack
« on: February 16, 2011, 03:33:06 pm »
I just recently put a reman starter with a lifetime warranty on my 85 Chevy C10. Battery had enough voltage to power the headlights and all other electronics. Tried to start but only got a click. Had a friend jump me, but again only got a click and then everything that was on, (CD Player display, and e-brake light when key put to start) went dead and had absolutely no power. Battery maybe? Any suggestions or advice?
'85 Chevy C10
Release the Kraken!
Re: New starter in truck, with jumpers on battery, no start.
« Reply #1 on: February 16, 2011, 03:40:04 pm »
Check your grounds and make sure it is all wired correctly.
Offline SSgt Smack
« Reply #2 on: February 16, 2011, 03:48:12 pm »
Checked and rechecked sir. Everything is wired correctly.
'85 Chevy C10
Release the Kraken!
« Reply #3 on: February 16, 2011, 04:27:14 pm »
Sounds like you may have one of the wires touching the starter housing which is a direct short. Check the fusible links and make sure all the wires are isolated from ground.
« Reply #4 on: February 16, 2011, 05:15:56 pm »
     If not the problem, you got a bad starter, not the first time, and wont be the last.
« Reply #5 on: February 16, 2011, 05:20:53 pm »
If he has no power now with the key on it's not the starter.
Offline SSgt Smack
« Reply #6 on: February 16, 2011, 06:11:10 pm »
Thanks for the info guys. I'll check on the wires and make sure they aren't making contact with anything they're not supposed to, pop a new batt in and see where it goes.
'85 Chevy C10
Release the Kraken!
