Author Topic: 9/1 Leaf Spring - Ride Quality Question  (Read 5462 times)
Offline SuperT
« on: February 22, 2011, 12:33:03 pm »
Hi,
I have a 1984 Chevy K30 DRW that I hope to convert to a utility body.  It's in need of new rear springs and I was curious if anyone has any experience with the ride quality differences  between 3950 lbs or 4650 lbs 9/1 springs.
I appreciate any opinions.
Thanks.
« Last Edit: February 22, 2011, 12:46:36 pm by SuperT »
Push to test, release to detonate.
Offline slammed79
  • Thou shalt not drive stock
Re: 9/1 Leaf Spring - Ride Quality Question
« Reply #1 on: February 22, 2011, 01:28:57 pm »
Welcome from Arizona. These trucks never rode too smooth from the factory, especially the 1 Tons. I'm sure someone will pipe up with preferences.
Praise the lowered
« Reply #2 on: February 22, 2011, 06:47:26 pm »
If you are adding a utility body I would size it accordingly.  with extra weight you won't notice it.
« Reply #3 on: February 22, 2011, 06:57:09 pm »
What axles are under it?
Offline SuperT
« Reply #4 on: February 22, 2011, 10:00:40 pm »
Thank you for the replies. The axles are Dana 60 front and 14 Bolt rear. I'm not sure if it's possible, but with the heavy springs, if I hit a bump in the road I'd rather it didn't sound like a small explosion.  I think the empty body is 1200-1300 pounds or so.
« Reply #5 on: February 23, 2011, 07:34:45 am »
     Like capt. said, you should estimate the weight of the utility body with what you are going to carry and talk to a local spring shop, they will calulate what springs to run and you wont even feel it with enough weight in back.
Offline Donut
« Reply #6 on: February 23, 2011, 07:36:48 am »
How much of a load are the boxes hauling?  I know they'll hold quite a bit and the weight adds up fast.
Maybe an overload spring setup?
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
