Author Topic: Common crank window problems  (Read 6965 times)
Offline J@meson
« on: February 23, 2011, 03:34:28 pm »
So my 87's passenger side window will not go down at all. I took the door panel off and looked inside and cant see anything irregular and the teeth all are lined up. I also cant grab the window and move it up and down as if it was off the track. Is there a common problem like this or am I going to have to remove the window and crank to find a problem?
1987 V10 tuff country 6in lift, 35x12.50 mud terrains, longtubes, tune
2002 Trans Am 6spd NHRA special edition
1975 Camaro
Offline jaredts
Re: Common crank window problems
« Reply #1 on: February 23, 2011, 05:13:24 pm »
You can't get the crank to move or it spins and the window doesn't move?
Offline J@meson
« Reply #2 on: February 23, 2011, 05:19:39 pm »
Crank doesnt move nore does the window...
1975 Camaro
« Reply #3 on: February 23, 2011, 06:07:40 pm »
Spray the joints with wd 40 or PB blaster
« Reply #4 on: February 24, 2011, 10:04:26 am »
My driver side did that till I replaced the regulator now it still has a hard time almost like its binding up I keep breaking the knob of the handle. There's three wheels on the regulator that slide in channels one the door spray them also
Offline jaredts
« Reply #5 on: February 24, 2011, 12:55:55 pm »
If soaking everything with penetrating oil solves it, cool.  I would put grease on all of the moving parts afterward if it works, though.  WD40 won't keep it moving smooth for long.
Offline Herleybob
« Reply #6 on: March 13, 2011, 02:14:34 pm »
My passenger side is really hard rolling down. Everything is greased good.
