Author Topic: how much lift for k30  (Read 11569 times)
Offline 84crew
« on: February 24, 2011, 09:58:24 pm »
Hi all. Im in need of some advice. I have an 84 1 ton crew cab 4x4. I would like to put some 35 inch tires on it and would like to know how much lift I will need. I have lifted half  tons, I know 4 inches will give enough room for 33s on a half ton but 1 tons sit a little higher in stock form. Will 31/2 to 4 inches be enough or do I need more? Thanks in advance for the help.
Re: how much lift for k30
« Reply #1 on: February 24, 2011, 11:16:01 pm »
It also depends on how wide the tires will be and the backspacing of the wheels.
« Reply #2 on: February 25, 2011, 01:31:36 pm »
     Are you planning on going off road or just dirt road type driving ?
Offline 84crew
« Reply #3 on: February 25, 2011, 07:38:45 pm »
Nothing to serious off road, I own a cj5 for that, just some height for when I need it. I prefer to run narrower tires without too much offset on the wheels.
« Reply #4 on: February 25, 2011, 08:08:53 pm »
Then I would just go 4"
Offline bowtieman82
« Reply #5 on: March 07, 2011, 05:38:26 pm »
do u plan on putting a heavy load on the truck, you know a trail. or any thing it the bed.  thats why one ton trucks have a higher stance, for the extra load capacity. i would go with a 6" lift.
« Reply #6 on: March 07, 2011, 06:18:04 pm »
Um.....the higher stance is not for the extra load capacity. Its because the 1 ton springs make the truck taller. You make it sound like the truck is higher to compensate for the sag.
Offline bowtieman82
« Reply #7 on: March 07, 2011, 09:05:38 pm »
the springs make taller because they are made to handle more load thats why they are called 1 ton not half ton. so if you plan on using it like it is made for then go for a 6" lift.
Offline thirsty
    • Suitor's Garage
« Reply #8 on: March 08, 2011, 05:12:08 am »
Are there load ratings for lift kit springs? I always assumed lift springs were lighter duty than 3/4 ton and 1 ton springs.
Offline bowtieman82
« Reply #9 on: March 08, 2011, 01:22:10 pm »
when u buy a name brand they have spring for 3/4 and 1 ton truck and HD truck you have to tell them what you have. they will cost more but are worth it.
