Author Topic: Monster Transmission  (Read 4045 times)
Offline TxFiddler
« on: February 25, 2011, 08:39:05 pm »
Since the big block is in the "final" stages at the machine shop, it's time to put in a tranny.  I am gonna go with a 700R4.  Has anyone ever purchased from, owned, or had any experience with Monster Transmission?  I do like the fact that they have a 3 year / unlimited mileage warranty.  The conversion pkg runs about 1800 bucks but has everything but the fluid.  Just wanting some info before "pulling the trigger".  Oh yeah, I'm changing from a TH350.
Thanks,
Fidd
80 C10 2wd / 427 BigBlock / 700R4 / 3:42 Eaton Posi LSD / 770 cfm Holley Street Avenger / Doug's Headers / MSD ProBillet Distributor / Champion 3 row Radiator
Re: Monster Transmission
« Reply #1 on: February 26, 2011, 06:37:59 am »
Can't help you out with monster transmission but what is up with the big block? Is the 700r4 you ordered going to handle the big block you're building?
Offline Psycho71
« Reply #2 on: February 26, 2011, 06:44:04 am »
PM sent
Offline Edahall
« Reply #3 on: February 26, 2011, 10:04:11 am »
That's a lot of engine for the 700r4.  Have you considered using a 4L80E?
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline TxFiddler
« Reply #4 on: February 26, 2011, 10:24:27 am »
I'm not planning on doing any towing with the truck.  I was going to the R4 mainly for the overdrive for when travelling on the highway.  Is the R4 weak behind a big block 427 that is used as a daily driver?  My engine builder says I can expect around 450 hp and 450 tq plus or minus a few. I also plan on going with an Eaton LSD and 3:42 gears.  This is a 2wd and not 4x4...not dropped or slammed but stock height.  Thanks again to all.  I will work on some pix later this evening.
Fidd
« Reply #5 on: February 26, 2011, 02:22:05 pm »
The 700R4 should work fine with the proper upgrades since you aren't building a nasty big block. The 4L80E is a better choice but more $$$
