Author Topic: soft brakes...  (Read 8612 times)
Offline txchainsawgogi
soft brakes...
« on: February 26, 2011, 04:33:36 pm »
any idea what would cause noticeably softer brakes in the course of a week? im not leaking brake fluid... but im sure i could use new pads. its on the to-do list!
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: soft brakes...
« Reply #1 on: February 26, 2011, 04:41:06 pm »
check master cylinder fluid level.
You could have air in the brake lines too, inspect the lines for any signs of wetness signalling a leak.  Take rear drums off and check for wetness on shoes.
If drums come off easily, your self adjusters may be bad and not adjusting the rear brakes.
I'd definately try and bleed the brakes.
Re: soft brakes...
« Reply #2 on: February 26, 2011, 04:55:59 pm »
it probably is the master cylinder starting to go. its got surface rust all over it, maybe it finally ate its way through.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: soft brakes...
« Reply #3 on: February 26, 2011, 05:08:29 pm »
i don't think it would rust too much inside where the fluid is.  I wouldn't replace the master cylinder w/out checking for leaks and bleeding the lines first.
Re: soft brakes...
« Reply #4 on: February 26, 2011, 05:12:08 pm »
i will check the lines but i dont know how to bleed anything bigger than a harley. i get the concept, i just havent done it myself before.
Re: soft brakes...
« Reply #5 on: February 26, 2011, 07:27:47 pm »
grimy, kind of moist surface rust.
you can kind of see it in the picture, but theres a leak coming from where the master cylinder bolts up.
Offline jaredts
Re: soft brakes...
« Reply #6 on: February 26, 2011, 07:59:13 pm »
Yep.  Get a new master cylinder.
Offline topp
Re: soft brakes...
« Reply #7 on: February 26, 2011, 09:03:19 pm »
And learn how to bleed the Master Cylinder, and brakes cause you'll NEED to do both after the replacement.
'90 Suburban TBI 350
Re: soft brakes...
« Reply #8 on: February 26, 2011, 09:32:16 pm »
alright so, the M/C bleed method is more or less the same as on a bike i assume, but what sort of tools am i lookin at?
is there a how to on here?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: soft brakes...
« Reply #9 on: February 26, 2011, 09:56:31 pm »
i think the bleed screws on brake calibers and wheel cylinders in shoes are either a 7/16" or 3/8" so get wrenches/sockets that size...i prefer flare wrenches to protect the screws from rounding off.  Start at the furthest wheel from master cylinder and work to closest.  Right rear, left rear, right front then left front.
Keep topping off the m/c or you'll be pumping air in again and starting all over again.  Bench bleed a new m/c prior to attaching the lines.
Re: soft brakes...
« Reply #10 on: February 26, 2011, 10:23:33 pm »
i guess im gonna have to buy a "one man" bleeder kit. i dont have anyone to help me do this haha how sad. should i get a bleeder system or one that pumps fluid into it? i've seen those in use and it looks super easy.
also, is this a p.o.s.? autozone seems to only carry FENCO brand m/c's as a direct replacement for mine.
http://www.autozone.com/autozone/parts/Fenco-Reman-Master-Cylinder-Brake-System/1978-Chevrolet-C10-1-2-ton-P-U-2WD/_/N-imvp7Z8kn47?counter=2&filterByKeyWord=master+cylinder&fromString=search&itemIdentifier=227967_56045_0_3912
« Last Edit: February 26, 2011, 10:32:59 pm by txchainsawgogi »
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: soft brakes...
« Reply #11 on: February 27, 2011, 11:40:00 am »
i rigged up a way to use a 2x4 board cut a certain length, and used a bunji cord to keep pressure on the board.  The top of the board had a V groove on it so the bunji cord wouldn slip, the board pushed the brake pedal down...worked pretty good.
Re: soft brakes...
« Reply #12 on: February 27, 2011, 11:58:39 am »
You need to "Bench Bleed" The master cylinder.
Just search bench bleed and you'll find this has been discussed several times.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5127.0
Re: soft brakes...
« Reply #13 on: February 27, 2011, 02:53:04 pm »
got it. bench bleed, then bleed each wheel. just pump it until no more air comes out then move to the next wheel.
Offline slammed79
  • Thou shalt not drive stock
Re: soft brakes...
« Reply #14 on: February 27, 2011, 03:22:03 pm »
When you bleed the brakes, start at the passenger rear, then move to the drivers rear, then the passenger front, then driver front. You want to work your way closer to the master cylinder, starting as far as possible from it.
Praise the lowered
