Performance
Open element ??????
Topic: Open element ?????? (Read 13933 times)
klaussk
Open element ??????
March 06, 2011, 01:36:09 pm »
I just recently purchased an 85 chevy k10 shortbed with a 305 in it. the truck is totaly stock. and other than the alternator that went bad the day i bought it the truck runs great. It has the original intake on it and i was wondering if i could put an open element on it. i ask because it has wat looks like a 1/2" a 3/8" and another verysmall hoses that connect to the intake that is on it now. does anyone know if it is even possible for me to put an open element on it or will it affect watever those hoses are attached to? ANd if I cant, does anyone know of a performance intake for it? Thank you
Go ahead hit it with a hammer. Theres only one level of broke.
bowtieman82
Re: Open element ??????
March 11, 2011, 08:58:13 pm »
where are those hose coming out. it sound like the emison hose is the a breather element in side the air cleaner where one of the hoses hook up. and do the other hose go to the front or the rear of the intake. post a pic of what it looks like when it on and off the truck.
Da67goatman
Site Supporters
Burban
March 11, 2011, 10:20:41 pm »
Kinda on topic: Is it OK to run an open element air filter on a TBI?
<Pitcrew>
1992 fullsize Blazer 4x4 35s no lift, 4.10s, Hella driving lights, TJ Flares, Huge bumpers, Snorkel, custom interior
Grim 82
March 11, 2011, 11:07:39 pm »
Quote from: Da67goatman on March 11, 2011, 10:20:41 pm
I've seen it done, not sure what changes (if any) you would have to make to get it to perform just right...
klaussk: You will need a breather for your valve cover and a cap for the thermostatic hose that you remove.
1979C20
Kyle Taulton.
March 12, 2011, 05:31:09 pm »
What is the tallest air cleaner element you can put on our truck without interfering with the hood?
klaussk
March 14, 2011, 06:50:58 pm »
Thanks guys. i went with the open element. and i put the breather filter on and capped the hos. it runs an awful lot better now.
March 14, 2011, 08:10:55 pm »
Just flip the lid over
jimmyjames
87 R10 Wrangler
August 09, 2011, 07:52:42 am »
I flipped my lid for awhile when i put a bigger muffler on it. Didn't cause any trouble, but no noticable difference, except for the noise.
78 Chevyrado
Z62 ON-ROAD
Site Supporters
August 09, 2011, 08:39:16 am »
if your stock intake has the cold air hose on it and is working properly (so the engine gets air from outside the engine compartment) you will lose power and mileage going to an open element because the engine can only get hot air thats just gone through the radiator.
westsidek20
August 09, 2011, 01:42:39 pm »
So a double cold air hose on a "stock" double intake tip (don't know really the name or that kind of intake, i know "HAULIN IT" has it on his truck) is better then an open element intake?
beastie_3
Josh
August 09, 2011, 02:05:22 pm »
technically yes.
Semper Fi
topp
August 09, 2011, 04:35:25 pm »
Here's what I did
Last Edit: August 09, 2011, 04:40:24 pm by topp
'90 Suburban TBI 350
beastie_3
Josh
August 09, 2011, 05:02:47 pm »
Its a misconception that an open air element is better than the stock setup.
Semper Fi
roadrage41
August 09, 2011, 10:56:31 pm »
One of the powerblock shows did a how to on making your own dual snorkel, I think spectre makes an add on for them as well. They came factory on certain fbodys but they sell for alot usually.
official go'fer/ broom pusher/ token fat guy of
www.yatesefi.com
Performance
Open element ??????
