Author Topic: Just Can't Decide......Need Suggestions  (Read 5578 times)
Offline TxFiddler
« on: March 08, 2011, 05:09:05 pm »
Ok, 2wd long bed 1980, stock height.  I want to get new rims and tires before the 427 goes in.  I am torn between the old school look of 15's and a lil more updated look of 17's.  Kinda like the Summit Legend 5, Torq Thrust II as well as the good ol' S/S.  I was gonna hold off till the motor was in but the Wilwood D52 calipers are rubbing on the factory rallye wheels just a bit.  So now is the time.  Should I stagger the front and rear or go with the same size on all 4 corners.  Suggestions, links, and pics are greatly appreciated.  I know, I will post pics of my build soon.......
Fidd
80 C10 2wd / 427 BigBlock / 700R4 / 3:42 Eaton Posi LSD / 770 cfm Holley Street Avenger / Doug's Headers / MSD ProBillet Distributor / Champion 3 row Radiator
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Just Can't Decide......Need Suggestions
« Reply #1 on: March 08, 2011, 05:21:53 pm »
Are you planning to lower or raise it or keep it stock height?
Here's the 18's on mine.  it's lifted a bit though.  I like the updated look to them.  18" Raceline Renegade 8 wheels and 33" tires.
Offline TxFiddler
« Reply #2 on: March 08, 2011, 05:28:13 pm »
Keeping it stock height.  I really like the way that yours turned out.  Very sharp truck.  Thanks for the info.
Offline Da67goatman
  • Burban
« Reply #3 on: March 08, 2011, 05:34:38 pm »
If you want to rotate your tires, I would get all 4 tires the same size, which means you could still stagger the rim widths, as long as your within acceptable widths for that tire.  For ex.  275/50r17 on 17x7.5 up front and 17x9 in the rear.  That way you can rotate the tires for even wear.
<Pitcrew>
Offline BigRuss
« Reply #4 on: March 08, 2011, 08:48:32 pm »
run 17's or if your wanting to a bit of both pick up some 16's... my truck is lowered a lil... 3/4 and its got the stock 15's with some Van wheel covers...
if your gonna be dumb you gotta be tough
