Performance
750 dbl pumper
Topic: 750 dbl pumper (Read 19754 times)
305chevy c-10
750 dbl pumper
March 12, 2011, 10:20:39 am »
has anyone ran a 750 holley dbl pumper on a mild 355 engine .or will it be just to costly to drive ....with gas 3.55gallon ...ifso what about a 600 or 650 dbl
Heartbeat of America yesterday's cheverolet
18T5C10
thirsty
Re: 750 dbl pumper
March 12, 2011, 05:57:01 pm »
I would run the 600.
Build thread
motion427
Re: 750 dbl pumper
March 12, 2011, 06:42:23 pm »
I'd have to agree,600-650 range for a mild 355 in a truck with a normal converter and mild gears.
Unless you would have like a 3000 RPM converter,and 4.11 ring and pinion,then a double pumper would be a good choice.
86 K10,350 Roller Cam,T350,NP205,10 bolt posi,12 bolt posi,33" tires.
85 K30,454,T400,NP205,Dana 60,14 bolt,being built now.
04 Avalanche Z71,6.0L,TVS 1900,Dynatech,Corsa,etc...
06 TBSS,AWD,6.0L,Kooks,C6 fan kit,etc...
75 Nova SS,502,T350,12 bolt
305chevy c-10
Re: 750 dbl pumper
March 12, 2011, 08:23:03 pm »
maybe a 2500 stall and 3.42 rpm air gap intake ,vortec style heads
18T5C10
roger97338
Re: 750 dbl pumper
March 17, 2011, 07:48:12 pm »
Over 15 years ago, I ran a 750 double pumper on a mild small block. It ran horribly, truly a waste of time and energy. Everyone I knew even told me before I did it that I shouldn't do it. But, the carb was free, blah blah blah...yeah. It didn't work out well at all. I think I traded it to someone for a 600 or 650.
three8six
Re: 750 dbl pumper
March 18, 2011, 09:29:15 am »
x2 what everyone else said, too big
figure843
Re: 750 dbl pumper
March 18, 2011, 05:45:35 pm »
I have a holley 600cfm with stock jets on my mild 350. runs perrrrrfect. You can always go with bigger jets and squirters.
1984 SILVERADO LWB 350/400
1988 SILVERADO K5 BLAZER 350/700R4/NP208/3:73/6"RC LIFT/38.5/15/15 BOGGERS
ToddN
Re: 750 dbl pumper
March 18, 2011, 05:47:14 pm »
750's are for big blocks. Period.
A government big enough to give you everything you need, is a government big enough to take everything you have.
slammed79
Thou shalt not drive stock
Re: 750 dbl pumper
March 20, 2011, 10:03:19 pm »
Quote from: ToddN on March 18, 2011, 05:47:14 pm
or smallblocks with forced induction!
Praise the lowered
the dan
Re: 750 dbl pumper
March 21, 2011, 01:41:14 am »
a nice 650 single pump vacuum secondary is the way to go for a mild street daily driver motor
team39763
Re: 750 dbl pumper
March 25, 2011, 05:15:03 pm »
A 750 can be made to work, you just gotta spend some time tuning it. I ran a 750 on my smallblock for years. I had problems, but I think they were due to the carb having trash in it, me not knowing how to tune, and a big vacuume leak. I've even used a 850 doublepumper on my motor when it was a little more stockish. If you're lookin' for gas mileage, you're lookin' at the wrong carbs.
305chevy c-10
Re: 750 dbl pumper
April 03, 2011, 05:10:03 pm »
ok i get it ......will go with 600-650 and electric fuel pump
18T5C10
305chevy c-10
Re: 750 dbl pumper
January 12, 2012, 09:15:54 pm »
i made i mistake my carb is a 750 with dual feed lines ,not a dbl pumper if this makes a difference in if it would work in my 383 app .
18T5C10
305chevy c-10
Re: 750 dbl pumper
January 13, 2012, 10:43:17 pm »
my carb is a 80508-1 holley daul feed elect choke /vac sec 750 .my question is has anyone ever put smaller jets in a 4160 carb like this.i think this route would be cheaper ( re-jet and rebuild it )verses buyin g a 650 carb for my 383 .i realy like the dual feed set up look .
18T5C10
necromonger
Re: 750 dbl pumper
January 14, 2012, 07:39:31 am »
you can't get calibration kit for a holly that i know of.That is why i like carter or Edelbrock If you have your timing right and your spark advance is tuned right you can tune them pretty easy.
new build,1978 chevy 3/4 ton 2 wheel drive 350 4 speed trans.
Performance
750 dbl pumper
