Author Topic: VSS Circut  (Read 24508 times)
Offline former520
VSS Circut
« on: March 14, 2011, 10:32:12 pm »
Now that the exterior paint is on the truck, the interior is due for attention.  When I was swapping in the new dash pad, one of the last mounting points of the cluster turned to dust.  The cluster is held in with a bunch of pieces of duct metal and screws.  I would like to replace the cluster entirely.  It does not line up with the cluster cover and makes it hard to read.
It is a 87 350 TBI with a TH400and I know it uses the VSS as a ECM input.  AFAIK, and thats not much, the VSS circuit is tied into the speedometer cable and cluster.   I would like to build a sheet metal dash, mount a gps unit to use for a speedometer, mount a tach and get oil, water, volt gauges to round it out.  Put some LEDS in for indicator lights and be done with it.
Here is the question.  Can I separate the VSS circuit from the dash and keep the ECM happy?  What is effect of running without the VSS circuit?  I know when I was driving around without the speedometer cable hooked up it would trigger a CEL light.
87 Regular Cab Classic Deluxe 20, 350TBI, TH400, 2wd
Offline topp
Re: VSS Circut
« Reply #1 on: March 14, 2011, 10:40:01 pm »
VSS tells the computer your speed....
That means the computer can tell speed and load to richen or lean out the fuel as needed.
It also tells the tranny when to lock the converter (if you have a 700 tranny).
'90 Suburban TBI 350
Offline jaredts
Re: VSS Circut
« Reply #2 on: March 15, 2011, 05:58:46 am »
You need the vss input from your speedometer.  The speedometer would be really easy to mount in your custom dash, just cut a hole and stick it in.  A truck with only a gps for a speedometer, blah.
Offline PromiseKeeper
Re: VSS Circut
« Reply #3 on: March 15, 2011, 06:58:01 am »
check out the local pull-a-part or other junkyard. You might be pleasantly surprised and it would be a whole bunch easier!
Offline former520
Re: VSS Circut
« Reply #4 on: March 15, 2011, 11:04:56 pm »
I understand the GPS dash is not everyones cup of tea.  I have them laying around and have had digital dashes in several things.  Less expensive than an I have a TH400, so no worries about lock up.  The dash in the truck is turning to dust and is jammed behind the metal and is going to come out in pieces (aka dust).  I am going to be stripping the interior out to complete the color change and start on the door cards.  I have not found any good dashes at any of the yards.  I did find my new dash pad and rear window though.
Offline slammed79
  • Thou shalt not drive stock
Re: VSS Circut
« Reply #5 on: March 15, 2011, 11:28:35 pm »
You will never find a good dash in an valley yard bud. I went to 6 different yards from Apache Junction to junkyard row and the best I found was still not that great.
Praise the lowered
Offline topp
Re: VSS Circut
« Reply #6 on: March 15, 2011, 11:30:36 pm »
With TBI your truck will always think it's doing 0mph without the vss, and will run lean....
Offline former520
Re: VSS Circut
« Reply #7 on: March 16, 2011, 09:07:11 pm »
I have had the results for clusters.  My only savior has been persistence and luck.  I found a dash pad that had a new overlay on it that is perfect and unfaded.  I also had the luck to find a fresh re manufactured alternator one morning as well.  I still need to find tail lights (there is usually plenty, just haven't grabbed any) and a better rear bumper.  I also have had no luck with power steering pumps either.  I may leave that broken, my shoulders are looking good!
Re: VSS Circut
« Reply #8 on: March 16, 2011, 11:58:43 pm »
Not sure about anywhere else but a no speedometer would fail it for inspection in New Hampshire.
Offline slammed79
Re: VSS Circut
« Reply #9 on: March 17, 2011, 12:05:56 am »
Let me know what you come up with for a rear bumper, the one on my 74 needs to go!
Praise the lowered
Offline FritzA
Re: VSS Circut
« Reply #10 on: March 26, 2011, 10:16:02 am »
If the VSS is stock in your 87, then yes you can run it straight to the ECM.
In 87 GM called it a VSS Buffer in the dash. The Buffer split the signal for the ECM and speedo. If you don't need the speedo then you can go straight to the ECM. It is the correct signal for the ECM as is if everything is stock. I think the 87 speedos used a signal light output to operate (a short lived bad idea).
In 90 GM went with the DRAC and a higher output VSS. The DRAC could convert the signal from the VSS into different output levels for the new all electric speedo, the ECM and the cruise control.
What are you going to do for a speedo? GPS? You could go with an electric speedo. Automer has electric ones that eliminate the need for the Buffer and DRAC if you only have the speedo and ECM. The Autometer speedo takes the feed from the VSS and has an output tab with the right signal for your ECM.
Re: VSS Circut
« Reply #11 on: March 26, 2011, 10:32:55 am »
Quote
I will have to disagree with this statement. The VSS has no effect on the air fuel ratio on these tbi trucks. FritzA is correct. One thing to keep in mind is the odomenter. If you plan to keep the truck forever, no big deal but if you sell it the truck will be TMU and depending on where it's being registered may cause problems.
Offline topp
Re: VSS Circut
« Reply #12 on: March 26, 2011, 10:48:09 am »
CODE 24
Trouble Code 24 indicates that the Vehicle Speed Sensor (VSS) is not sending the expected (based on other system parameters like LV8, TPS, RPM etc.) signal to the ECM.
Code 24 will be set if vehicle speed equals zero 0 mph when:
1 VSS indicates less than 2mph.
2 MAP is less than 30 kPa.
3 Engine speed is between 2200 and 4400 RPM
4 TPS is less than 2%.
5 Not in Park or Neutral
6 No Code 21, 22, 33, or 34.
7 All conditions met for 3 seconds
If the code was logged when the vehicle was in motion, the following should be checked:
1. VSS circuit open, shorted to ground, shorted together
2. Faulty Connections
3. Defective VSS
4. Defective ECM
5. A faulty or misadjusted Park/Neutral (P/N) switch can result in false Code 24.
Or :
OK, here is what "Chevrolet TPI & TBI Engine Swapping" says:
Regarding the VSS:
The VSS tells the ECM how fast the vehicle is going. Most people think the VSS is only used for for the lock-up torque convertor. The VSS is also used to control the EGR valve, the charcoal canister purge valve, the electric cooling fans, idle speed, and air/fuel ratio.
It must be emphasized that the VSS is used to control the idle speed when the vehicle is moving. Without the VSS the vehicle may have stalling problems under certain conditions. The reason an engine not equipped with VSS may stall is because when the ECM has the signals that indicate the engine should be idling (foot off gas, vehicle moving less than 2 MPH), idle speed is closed loop ( which is not the same as the O2 sensor running closed loop) and the ECM will try to maintain a programmed idle speed. If the vehicle is moving, the ECM opens the IAC (idle air control) a programmed amount, regardless of engine speed, which is usually a position that will make the engine idle about 50-100 RPM above the programmed idle speed. Stalling can occur when the vehicle is in the over-run condition (foot off gas- engine speed above the programmed idle speed) because the ECM will try to lower the idle speed to the stationary programmed speed. The IAC may not be able to open rapidly enough to prevent the engine from stalling.
Raising the minimum idle speed with the adjusting screw can eliminate stalling, but the engine will not run optimally without a VSS. Some Chevrolet engines are programmed to run lean under highway mode. Without VSS the ECM will not get the signals to run the engine for best fuel economy. There are a lot of other programs in the ECM which depend on the VSS.
And in '87, the speedo/odometer was still cable driven.....
« Last Edit: March 26, 2011, 10:50:46 am by topp »
Re: VSS Circut
« Reply #13 on: March 26, 2011, 11:17:56 am »
topp, I think you are mixing up TBI and TPI. TBI is speed density and fuel metering is not controlled by vss input on an 87 tbi truck.
The vehicle speed sensor (VSS) sends a pulsating voltage signal to the ECM, which the ECM converts to MPH. This sensor mainly controls the operation of the transmission Torque Converter Clutch (TCC), shift light and cruise control (if equipped).
Nevertheless In either system the vss although an important input will have very little affect on a/f ratio if the circuit is open. The ECM will easily correct the a/f ratio and will ignore the vss signal if a fault is detected therefore I will again have to disagree with your statement suggesting the truck will run lean.
Look on your scan tool at fuel integrator and block learn while driving down the road. Now unplug the vss and monitor fuel integrator and block learn driving exactly the same down the same road.
Offline topp
Re: VSS Circut
« Reply #14 on: March 26, 2011, 11:40:24 am »
Not at all...
It's OK.  I Can utilize my manuals and Software which tells me that the VSS IS used for more than just TC Lockup on ODB1 systems...
We agree to disagree.
http://www.jagsthatrun.com/Pages/SpeedSensors_Speedometer.html
« Last Edit: March 28, 2011, 07:19:28 pm by Captkaos »
