Author Topic: electrical issue?  (Read 5445 times)
Offline txchainsawgogi
electrical issue?
« on: March 17, 2011, 09:53:47 pm »
today after 15 minutes of driving in traffic i pulled over at a gas station. got a drink and got back in, turned the key... no power.
lifted the hood and looked around. battery terminals on tight. all grounds looked fine. its a brand new battery and alternator.
got back in and it started fine.
what would cause a loss of electrical power that only lasts 5 minutes?
Offline 1980c10
Re: electrical issue?
« Reply #1 on: March 17, 2011, 11:09:43 pm »
tighten all of your connections on your starter and alt
« Reply #2 on: March 17, 2011, 11:18:36 pm »
X2 on starter wire. Did it make any noise at all?
« Reply #3 on: March 18, 2011, 12:22:52 am »
No noise, no lights came on...it acted like the battery wasn't even under the hood.
Offline 1979C20
  • Kyle Taulton.
« Reply #4 on: March 18, 2011, 02:05:20 am »
Ignition switch going out, maybe? Maybe when you turned the key it didnt make the connection the first time. And when you turned it the second time it worked?
« Reply #5 on: March 18, 2011, 02:23:23 am »
Could be. I mean not even the cd player came on. Ignition switch sounds more likely than starter...though I do need to replace the starter asap.
Offline slammed79
  • Thou shalt not drive stock
« Reply #6 on: March 18, 2011, 02:32:30 pm »
Might wanna check the positive battery cable running to the starter and make sure its not touching your headers. The heat will burn through the insulation and it'll ground out on the exhaust. Moving it around may have gotten it off the header, thus no more ground.
I killed an Optima that way, it may be worth a look.
Praise the lowered
« Reply #7 on: March 18, 2011, 03:03:29 pm »
The little red wire on the starter will kill everything if not hooked up or bad connection
« Reply #8 on: March 18, 2011, 08:43:36 pm »
im just gonna replace the starter and clean up the wires just to be safe. its old any ways
« Reply #9 on: March 18, 2011, 11:54:32 pm »
tx replacing the starter doesn’t have to be done. iv seen new starters go bad with in a week. Make sure it’s your problem cause it might cause more problems down the road
« Reply #10 on: March 19, 2011, 12:44:23 am »
the starter has a crack in it anyway, and im sure its original.
« Reply #11 on: March 19, 2011, 08:38:02 am »
Ok yeah that could be a problem. Lol
