Performance
Poping through exhaust
Topic: Poping through exhaust (Read 7652 times)
BULLDOG
March 18, 2011, 08:21:07 am »
I have a Goodrich crate engine with a Edl performer and a Edl 600 carb with headers and when you let off the gas it pops through the exhaust.
Anyway I can stop the poping?
Black 1983 K20 and sm 465
Grim 82
Re: Poping through exhaust
March 18, 2011, 09:02:28 am »
Yeah, just don't ever let off the gas
Sounds like it might be getting too much fuel or not enough timing advance, or a little of both.
topp
March 18, 2011, 09:15:01 am »
A small exhaust leak can also cause that....
'90 Suburban TBI 350
March 18, 2011, 11:46:41 am »
Check the basics first,
No vacuum leaks, plugs gapped right, wires, cap & rotor, timing, firing order etc. If OK start with a compression test.
BULLDOG
March 18, 2011, 03:58:41 pm »
Well its when say you are coming into a stop light and you let off the gas and dont push in the clutch it pops ,so I think I will plug off the vac ports on the carb and see if it still pops.
onelow84
March 18, 2011, 06:27:32 pm »
x2 on exhaust leak possible
1979C20
Kyle Taulton.
March 19, 2011, 04:54:25 am »
You said you have headers, but what do you have for exhaust? I have a manual tran too and headers with glasspacks right after that dump out in front of the gas tanks, towards the ground. When I let of the gas in any gear, or downshift, it backfires quite a bit because there isnt much back pressure. so what do you have for exhaust?
BULLDOG
March 19, 2011, 10:00:22 am »
There is flexible pipe coming off the back of the headers and 3 feetish of pipe and then a thrush muffler on both sides.
March 19, 2011, 12:29:55 pm »
You need a real exhaust system or it's going to sound like a garbage can with firecrackers blowing up inside it. Have an exhaust shop make a secure connection from the collector to the pipe.
Psycho71
March 20, 2011, 06:40:35 pm »
My '71 has a short exhaust system like the OP describes. Short offsets from the headers to the 40series flows, then turns down from them right behind the cab. It would "back-pop" horribly when deccelerating. I put in an H-pipe and it quit. The mufflers still drone like crazy, that's another matter entirely, but no more popping what so ever. I guess allowing the banks to equalize fixed the popping.
Performance
