Author Topic: new brake booster and the 3d gear drive problems  (Read 5631 times)
Offline log1000
« on: March 21, 2011, 07:30:52 am »
now the trucks brakes are sticking after we put in a new brake booster and the 3d gear drive is slipping what do i do to fix the brakes, and the 3d gear drive? ??? :'(
« Last Edit: March 22, 2011, 03:50:44 pm by Captkaos »
Re: new brake booster and the 3d gear drive problems
« Reply #1 on: March 21, 2011, 09:50:04 pm »
Different size booster? Is the rod length correct? Is the trans fluid low? Did you overheat it? Bubbles in the fluid?
« Reply #2 on: March 21, 2011, 11:27:08 pm »
are all four wheels sticking. when was your last trans fluid change?
