Author Topic: Idle Speed  (Read 9602 times)
Offline Tazman
Idle Speed
« on: April 19, 2011, 04:02:45 pm »
I know the idle speed is set by the ECM on TBI motors but how many RPM's should that be?Thanks
God BLESS AMERICA
Offline topp
Re: Idle Speed
« Reply #1 on: April 19, 2011, 06:55:20 pm »
To set your Idle speed on a TBI-
Jumper the A+B terminals on your ALDL (top two right ones).
Turn key to run.
Wait 30 seconds.
Unplug IAC
Turn key to Off
Remove Jumper.
Start truck.
Set Idle to 550 RPM.
Shut off truck.
Reconnect IAC
The ECM will take over.
'90 Suburban TBI 350
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Idle Speed
« Reply #2 on: April 19, 2011, 11:02:54 pm »
Turn key to run.
Wait 30 seconds.
Unplug IAC
Turn key to Off
Remove Jumper.
Start truck.
Shut off truck.
Reconnect IAC
If only we knew all this stuff back in '87...
Offline topp
Re: Idle Speed
« Reply #3 on: April 19, 2011, 11:41:16 pm »
Yea right?
Imagine what we'll know in 25 years about todays computer controlled vehicles......
Offline slammed79
  • Thou shalt not drive stock
Re: Idle Speed
« Reply #4 on: April 20, 2011, 01:01:34 am »
Yea right?
If any of todays vehicles are still around. They don't build them like they used to
Praise the lowered
Offline crunchie
Re: Idle Speed
« Reply #5 on: May 26, 2011, 11:21:50 pm »
Gee whiz this works! Does anyone know what this is actually doing and why this exists?
Is this a procedure that was done at the dealerships back in the day when someone complained about idle speed? How would I change this back if I wanted to?
I swear this changed the behavior of my truck in driving situations too. After my drive home tonight I performed this procedure and immediately it seemed to change not only the idle but the shift points are a little earlier, it's quieter on the highway for sure (I have true duals with no cats and glasspacks, audible changes are VERY noticable) and it seems to downshift nicer too. Overall I like the changes but I'm just wondering what this procedure was meant for from the factory.
Re: Idle Speed
« Reply #6 on: May 27, 2011, 10:33:45 am »
Your ECM has what's called adaptive strategies which allows the ECM to learn known good values which can actually be "off" when there are other underlying issues. If an issue has been corrected, throttle body cleaned, tune up, etc you should reset the min IAC & TPS voltage. There are many ways in which you can do this.
GMC NUMBER: 88-T-55
GROUP: 6E - Engine Emissions
DATE: November, 1987
CORPORATENUMBER: 836302
SUBJECT: TRUCK ENGINE CONTROLLED IDLE SPEED AND MINIMUM IDLE AIR
RATE SPECIFICATIONS
MODELS: 1987 AND 1988 TRUCKS (ALL GASOLINE ENGINES) WITH THROTTLE BODY
INJECTION (TBI)
This bulletin defines the controlled idle speed and minimum idle air rate specifications for 1987 and 1988 model year trucks for all engine applications with TBI. Additionally, step by step procedures are provided for performing the controlled idle speed check and the minimum idle air rate check. It is important that these procedures and specifications be adhered to. An incorrect readjustment with a high minimum air rate will cause the Idle Air Control (IAC) valve pintle to constantly bottom on its seat and may result in early IAC valve failure. A minimum air rate that is too low may result in a no-start condition in cold weather, a stall after start or a stall during deceleration, because of poor air/fuel distribution through the throttle bore.
NOTICE: THESE SPECIFICATIONS AND PROCEDURES SUPERSEDE THOSE PROCEDURES DEFINED IN THE 1987 FUEL AND DRIVEABILITY MANUAL, X-8736.
Controlled Idle Speed Check
Before performing this check there should be no codes displayed, idle air control system has been checked and ignition timing correct. The procedures to check the idle air control system can be found in the Light Duty Truck Fuel and Emissions service manual at the following locations:
All Truck Engines Except 2.5L       Page 4-11
2.5L Truck Engines                  Page 3-61
1. Set parking brake and block drive wheels.
2. Connect a "SCAN" tool to the Assembly Line Data Link (ALDL) connector with tool in Open Mode.
3. Start engine and bring it to normal operating temperature.
4. Check for correct state of Park/Neutral switch on "Scan" tool.
5. Check specifications chart at the end of this bulletin for controlled idle speed and IAC valve pintle position (counts).
6. If within specifications, the idle speed is being correctly controlled by the Electronic Control Module (ECM).
7. If not within specifications, refer to "Rough, Unstable or Incorrect Idle, Stalling" in Section "2" of the Fuel and Driveability Manual X-8736 and review information at the beginning of this check.
MINIMUM IDLE AIR RATE CHECK
1. Check controlled idle speed and perform idle air control system check first.
2. Set parking brake and block drive wheels.
3. Start engine and bring it to normal operating temperatures (85-100 degrees Celsius). Turn engine "OFF".
4. Remove air cleaner, adapter and gaskets. On S/T series vehicles, leave THERMAC hose connected. Check that the throttle lever is not being bound by the throttle, Throttle Valve (TV) or cruise control cables.
5. With IAC valve connected, ground the diagnostic terminal (ALDL connector).
6. Turn "ON" ignition, do not start engine. Wait at least 10 seconds (this allows IAC valve pintle to extend and seat in throttle body).
7. With ignition "ON", engine stopped, test terminal still grounded, disconnect IAC valve electrical connector. (This disables IAC valve in seated position). Remove ground from diagnostic terminal.
8. Connect a "Scan" tool to the ALDL connector and place in open mode. If a tool is not available connect a tachometer to the engine.
9. Start engine. With transmission in neutral, allow engine rpm to stabilize.
NOTICE: ON 2.5L ENGINES A SERVICE ENGINE SOON LIGHT WILL COME ON AND A CODE 35 WILL BE SET.
10. Check rpm against specifications at the end of this bulletin. Disregard IAC counts on "Scan tool with the IAC disconnected. If the engine has less than 500 miles or is checked at altitudes above 1500 feet, the idle rpm with a seated IAC valve should be lower than values in chart.
11. If the minimum idle air rate is within specifications, no further check is required.
12. If the minimum idle air rate is not within specifications, perform the following procedures:
13. If present, remove stop screw plug by piercing it with an awl, then applying leverage. The screw is covered to discourage unauthorized adjustments.
14. With engine at normal operating temperature (85-100 degrees C), adjust stop screw to obtain nominal rpm per specifications with seated IAC valve.
15. Turn ignition "OFF" and reconnect IAC valve electrical connector.
16. Disconnect "Scan" tool or tachometer.
17. Use silicon sealant or equivalent to cover stop screw hole.
18. Install air cleaner, adapter and gasket.
19. On 2.5L engines, clear Code 35 that has been set.
Offline crunchie
Re: Idle Speed
« Reply #7 on: May 27, 2011, 01:48:38 pm »
Thanks a bunch for the extra info!
Re: Idle Speed
« Reply #8 on: June 27, 2011, 04:29:07 pm »
