Author Topic: Sloppy tilt column  (Read 6900 times)
Offline Psycho71
Sloppy tilt column
« on: April 22, 2011, 08:34:34 pm »
My steering column is sloppy, both vertically and side to side. Feels like it's at the knuckle. Had a fella tell me there's four bolts in there to tighten, and it's fairly common to see the 80's model full sizes with this issue. I've never been into one of these columns. I would not consider him as reliable a source as I would some people here.  Is he right, or am I looking at more than a tear down and re-assemble job?
Offline Grim 82
Re: Sloppy tilt column
« Reply #1 on: April 22, 2011, 08:40:11 pm »
Sounds like a classic take it apart and put it back together project.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=12525.0
« Reply #2 on: April 23, 2011, 12:06:10 am »
It is way easier than it looks/seems. I just did it two months ago.
Offline Psycho71
« Reply #3 on: April 23, 2011, 12:21:01 am »
Cool. Looks like I'll need to grab a few of the specialized tools before I attack this. Thanks for the link! Guess I should have used the search feature first.
« Reply #4 on: April 23, 2011, 12:42:14 am »
no worries. you should be able to rent the wheel puller, lockplate tool, and pivot pin removal tool at orilleys or autozone. one word of advice, lay out everything you remove in the order you removed it and keep everything face down or up.
Offline slammed79
  • Thou shalt not drive stock
« Reply #5 on: April 23, 2011, 05:19:38 am »
What he said... I've spent a fair amount of time in the yards lookin for the parts I lost from doing this!
Praise the lowered
