Author Topic: roof seams  (Read 5539 times)
Offline 77 cc lb
roof seams
« on: April 23, 2011, 02:59:21 pm »
hey everyone, i was wondering what you would use to repair the seam around the roof line? looks like it was a silicone or caulking.
87 Chevy crewcab shortbed soon to have a 454/400
Offline jaredts
Re: roof seams
« Reply #1 on: April 23, 2011, 03:07:32 pm »
Someone correct me if I'm wrong, but pretty much if its on a car or truck and looks like caulk its seam sealer.
Re: roof seams
« Reply #2 on: April 23, 2011, 03:19:26 pm »
Seam sealer. You will have best results if you dig all the old crap out with a utility knife or something. Then sand the seam with a piece of 220 folded in half, prime with self etching, a catalyzed urethane primer. Spread the seam sealer into the seam, then was excess off, and smooth up the sealer in the seam with lacquer thinner.
Re: roof seams
« Reply #3 on: April 23, 2011, 05:49:37 pm »
Ditch the seam all together if you're at that point.
Offline 77 cc lb
Re: roof seams
« Reply #4 on: April 23, 2011, 07:50:09 pm »
thanks guys. i wasn't sure what it was. mine is starting to separate and was wondering what it was. vilezambonie would it be a matter of just cleaning it out and bondo-ing the area. i've got a dent in the top back corner by the slider, is there access to pop it out or would it be best to bondo that area as well? any suggestions would be appreciated.
Re: roof seams
« Reply #5 on: April 24, 2011, 12:49:07 am »
If your going to fill the seam it needs to be welded. Body filler will crack and fall out.
Offline 77 cc lb
Re: roof seams
« Reply #6 on: April 24, 2011, 07:09:18 am »
thanks blazin', appreciate the info!
