Author Topic: Carburetor to Throttle Body ?  (Read 3361 times)
Offline rwhit57
« on: April 24, 2011, 08:33:49 pm »
Has anyone changed an early (pre-87) truck from carburetor to throttle body? If so, I assume you need the computer and harness, the throttle body system and an elect. fuel pump. What else?. Would it be worth the trouble, if I could find a good used set-up? I have had a few 87 models that ran good and got decent mileage. My truck's gas mileage is starting to wear on me.  Thanks, Randy
Randy from Okla
Whoever said "Money can't buy happiness" has obviously never seen a speed shop!
Re: Carburetor to Throttle Body ?
« Reply #1 on: April 24, 2011, 11:33:09 pm »
Yes I have done it. Check out my mutt project. Is your engine stock?
Offline rwhit57
« Reply #2 on: April 25, 2011, 11:51:47 pm »
It is a stock GM Goodwrench 350 with headers. After I changed intakes and swapped out the old Q-jet for an Edel 600, my gas mileage sucks. I'm going to go to a 700r4 later and maybe try a different carb, but I like the idea of the throttle body. Was it worth the trouble? Could you lead me to the mutt project?  Thanks, Randy
Randy from Okla
« Reply #3 on: April 26, 2011, 08:29:57 pm »
     You can find vile's mutt project here.    http://forum.73-87chevytrucks.com/smforum/index.php?topic=6233.0.  Or search under members rides for mutt.
Offline rwhit57
« Reply #4 on: April 26, 2011, 11:41:37 pm »
Hey Thanks!
Randy from Okla
