Author Topic: New Dash Install  (Read 15878 times)
Offline Andcryr1
New Dash Install
« on: April 29, 2011, 08:45:14 pm »
Hey guys....been working on the inside of my cab. getting it ready for summer. Ran into a little problem tonight. Went to install new dash. After a little loving....its in. However, I have not figured out where the last screw on the left side of the dash goes. I'm thinking it has something to do with my dash bezel, but no luck. Please help. I'll try to get some pictures together tomorrow. I'm also having problems trying to reinstall the dash bezel as well.
Re: New Dash Install
« Reply #1 on: April 29, 2011, 09:11:05 pm »
     First thought, a lot of people on here have bought aftermarket dashes and were not happy at all with them.  Maybe the new dash had 1 less hole.
Offline Andcryr1
« Reply #2 on: April 29, 2011, 10:54:28 pm »
Its supposed to be screwed in at the bottom left of the dash. Supposed to hold it in place. But not sure exactly how it goes. and yes it is an aftermarket dash.
Offline Andcryr1
« Reply #3 on: April 30, 2011, 04:49:48 pm »
whats the best way to post pictures on the forum
Offline Canadian 4X4
« Reply #4 on: April 30, 2011, 04:53:24 pm »
I use photobucket and link it that way
Offline Andcryr1
« Reply #5 on: April 30, 2011, 05:25:12 pm »
« Reply #6 on: April 30, 2011, 08:55:52 pm »
     I am sure I will be corrected if I am wrong, but I believe that area is suppose to have a clip that holds it in not a screw.
« Reply #7 on: April 30, 2011, 09:06:01 pm »
Take it back out. You don't have the clips engaged into the slots on the metal frame.
Offline 73ratrod
« Reply #8 on: May 01, 2011, 01:13:34 am »
what website did u get that dash from? really clean look
.........________//__{\_____
,,,,,,,,,/__(O)__/____/_(O)_/chevy
Offline Andcryr1
« Reply #9 on: May 01, 2011, 09:33:08 am »
I've taken it out a couple times and reinstalled. I think the dash shrunk while it was being cooled. Its as if the dash is just a little to small for the truck and the accessories. Talked to the supplier yesterday. They're supposed to get back with me on Monday.
got it from the site recommended here at the forum
« Reply #10 on: May 01, 2011, 09:46:18 am »
Take the dash back out. Remove the mounting clips and see if it lays in flush. If it does that means the dash is fine, you are just not engaging the slots in the metal frame when you are installing it.
Offline Andcryr1
« Reply #11 on: May 01, 2011, 09:50:10 am »
Will do this afternoon.....Did u notice in the pics that the trim for the right side of the dash is longer than the actual dash itself. That and having major difficulties getting the dash bezel in is making me think the dash is to small.
« Reply #12 on: May 01, 2011, 09:58:55 am »
Is this dash rubbery and floppy or is it solid like the factory dash. In other words if you remove the dash pad and are holding it will it flop or is it solid? If it's the rubbery blob dashes direct pad it will not fit right and you may as well return it before it's too late. They are garbage and will not fit right.
Offline Andcryr1
« Reply #13 on: May 01, 2011, 10:02:47 am »
yep its rubbery and floppy.....what's your recommendation for a new dash?
« Reply #14 on: May 01, 2011, 10:07:14 am »
Eww, Return it. According to what I've heard from Chris is they make this one he sells that is almost as good as GM. http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=D100181&Category_Code=DC
Then there's the GM dashes which you may be able to locate through a dealer or find an NOS one kicking around (Craigslist/eBay). You can restore your factory one if you aren't picky but it will never be as good as a replacement. Chris may have some factory pads left as well if you check with him.
The dashes direct one you have might be good for a farm truck or a beater but it's nothing I would ever use.
