Author Topic: 87 Chevy Custom Deluxe 305 cranks but wont start  (Read 10805 times)
Offline tmedic
« on: April 30, 2011, 10:05:52 am »
 I have an 87 Chevy 305 TBI 1/2 ton 4wd. I had a leaking head gasket. Pulled the heads ,had them inspected and surfaced. During the repair I replaced rocker arms ,pushrods, distributer, wires, plugs. After all this my truck would just not start at times . No pattern to it at all. I could turn the key , it would crank but not start. Pour fuel into the TBI and it would start. Fuel is coming from the pump. I pulled the fuel line off the TBI and had plenty. Replaced the fuel pressure reg. ECS, TPS,Ignit Mod. Map sensor, EGR, O2 sens. fuel pump ( that sucked) . I am not getting any fuel out of the injectors when i crank the engine. Fuses are good. No one around rents/loans the fuel pressure guage and its $45 to buy. Nobody has a noid light either  , would have to order. Can I check the injectors with just a test light? I am not very electrical /automotive savvy but I am learning through expereince. Before all this I was getting 17 mpg now when she runs I am at 12mpg.  Any help would be appreciated.
Re: 87 Chevy Custom Deluxe 305 cranks but wont start
« Reply #1 on: April 30, 2011, 11:09:24 am »
OK since you don't have a scan tool, unplug the TPS and see if it starts.
report
Offline tmedic
« Reply #2 on: April 30, 2011, 12:28:26 pm »
Ok I left about an hour ago and decided to try it just for fun. It started . I shut it off and when I came back it would not start again. I unhooked the throttle position sensor and it started up.
Offline tmedic
« Reply #3 on: April 30, 2011, 12:36:32 pm »
With it running I hooked the TPS back up and the engine idled down slightly. I unplugged it again and it idled up.
Offline tmedic
« Reply #4 on: April 30, 2011, 12:42:56 pm »
I got ahold of a noid light and plugged it in while it was running. I checked both injectors and they are both flashing very fast and at the same rate.
Offline tmedic
« Reply #5 on: April 30, 2011, 03:55:30 pm »
I have been looking at this thread   http://forum.73-87chevytrucks.com/smforum/index.php?topic=17537.15     and wondered where I can find charts A-1 A-2 A-6?
« Reply #6 on: April 30, 2011, 09:20:31 pm »
So are you saying the no start problem goes away with the tps unplugged?
Offline tmedic
« Reply #7 on: May 01, 2011, 05:17:32 am »
Yes.  When I unplugged the TPS it started. But I plugged it back in and waited about 30 minutes and it started fine. It may start the next 3 times I turn the key but then wont start for days.
Offline tmedic
« Reply #8 on: May 01, 2011, 10:55:19 pm »
Went to work today for 12 hours and when I came home I tried to start it - No Go. Unplugged the TPS    still wouldn't start.
« Reply #9 on: June 30, 2011, 01:23:01 pm »
Where are you with this?  Did you get it resolved?
Offline tmedic
« Reply #10 on: June 30, 2011, 03:25:32 pm »
Yeah finally figured it out. I disconnected all the hot and ground wires in the engine compartment. Payed close attentions to the ones that were disconnected when I replaced the head gaskets. They all seemed tight but I cleaned the connections really good then reconnected them and I haven't had a problem since.
Offline tmedic
« Reply #11 on: June 30, 2011, 03:27:59 pm »
Gas mileage is still down but atleast it starts when I want it to. I am picking up a code 44 so I am going to try and replace the O2 sensor. The connections to the computer appear good.
