Author Topic: 1974 C65 windows?  (Read 7169 times)
Offline gotsmeuhh350
1974 C65 windows?
« on: May 01, 2011, 01:46:02 am »
Well i have been driving my truck for the past 2 months without a drivers side window,
and living in michigan, its not very fun. well we have an old dump truck that we havent
used in a long time so i was wondering if a drivers side window out of the dump truck will fit
in my 86 K10. Thanks
87 V10, 350 T350, 2 3/4 stacks, stock tbi (sold)
86 K10, 350 T350, headers, edelbrock carb, duals (scrapped)
86 C10, rust free roller, (sold)
86 C15, 305 700r4, stock. everything. daily driver/project
Offline Camfirchev
Re: 1974 C65 windows?
« Reply #1 on: May 01, 2011, 03:31:25 am »
If I remember correctly the glass thickness might be a little too thick for the window channel,  but you might be able to swap over all the window felts to get it to work...
« Reply #2 on: May 01, 2011, 08:01:05 am »
Should fit fine. The 86 has thinner glass even in the medium duty trucks. think it was around 78 / 79 they started using thinner side glass in all GM trucks C / K 10s right through the C 70s. As stated you might have to use the felt channels too.
« Reply #3 on: May 01, 2011, 11:13:33 pm »
well my doors are off of a 76 K10. if thatll matter. i guess ill just have to try and see. thanks for the help
« Reply #4 on: May 02, 2011, 05:46:54 am »
Should fit fine either way, 76 doors probably won't need to swap the track felts.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #5 on: May 02, 2011, 08:58:32 am »
Here's a pic I took of the difference between 73-80 and 81-up window channels.  They are both new and aftermarket.
Top is a 73-80 seal and bottom is 81-up seal.
« Reply #6 on: May 03, 2011, 08:19:01 pm »
my window channels are long gone, the only thing i need a window for is the rain. cause i really dont like getting in and having a wet ass for the entire day. and if its raining, i usually dont drive it. so would i really have to change anything to get it to work? just to be held in and keep my interior from getting wet?
Offline Camfirchev
« Reply #7 on: May 18, 2011, 10:17:57 pm »
Is all the window felt trashed?   On most trucks of this age the horizontal window felts inside and out are most likely already gone and dry rotted, but the vertical window felt that goes up and around the top of the door is where I would think you would have a problem.
  • Z62 ON-ROAD
« Reply #8 on: May 19, 2011, 12:40:58 am »
For what you're wanting, they'll work just fine.  If you can though try to use some kind of rubber something in the front channel on the vent window.  if there's no rubber anywhere to cushion the glass, one good bump and it'll shatter it.  Just look to have it cushioned in the rolled down position.
« Last Edit: May 19, 2011, 12:42:33 am by 78 Chevyrado »
