454 oil pan Gasket.
Topic: 454 oil pan Gasket. (Read 9442 times)
pedigo78
Big Blue
454 oil pan Gasket.
May 03, 2011, 07:09:39 pm »
I have a 85 K20 that was orginally a C10. It has a 454 in it know and the front lip seals has a small leak. I got a new preformed gasket and I noticed that I will not be able to pull the pan with the cross member there. So should I remove the cross memeber, or just lift the engine? I feel like removing the cross memeber would be the ez way to do it.
Sgt Pedigo USMC
beastie_3
Josh
Re: 454 oil pan Gasket.
May 03, 2011, 07:40:45 pm »
doesnt the crossmember hold the motor mounts?
Semper Fi
TxFiddler
May 03, 2011, 10:30:59 pm »
I'm in the process of putting a 427 (which is a 454 block) where a 350 came out of and there is plenty of room to take the oil pan and gasket off. Not quite sure what you are working with. Any pics?
80 C10 2wd / 427 BigBlock / 700R4 / 3:42 Eaton Posi LSD / 770 cfm Holley Street Avenger / Doug's Headers / MSD ProBillet Distributor / Champion 3 row Radiator
ccz145a
May 04, 2011, 12:49:51 pm »
You can get at it by easing the engine up, careful of the distributor. Dont take the xmember out.
beastie_3
Josh
May 04, 2011, 02:13:16 pm »
take the cap off your dizzy, or pull it out completely just to be sure, IMO.
Semper Fi
pedigo78
Big Blue
May 04, 2011, 06:01:30 pm »
OK, thanks for all the input. By the way what is a dizzy?
Sgt Pedigo USMC
beastie_3
Josh
May 04, 2011, 06:08:46 pm »
distributor
Semper Fi
fitz
May 04, 2011, 06:17:51 pm »
As far as removing the crossmember, isn't your riveted on? Not impossible to remove but it would require some grinding or torches. I would not go that route.
Keep in mind that if your truck did not come from the factory with a BB it may still have the SB motor mounts in it. I believe this would place your oil pan a little closer to the crossmember than if you have the BB motor mounts.
If this is a truck you plan on keeping I would think about pulling the motor and replacing all the oil related gaskets (including the rear main seal and the timing chain cover seal/gasket).
May 04, 2011, 06:32:16 pm »
You do not need to lift the engine up unless your engine mounts are toast.
FYI - select new topic not new poll
pedigo78
Big Blue
May 04, 2011, 07:03:38 pm »
How can I tell what mounts I have?
Sgt Pedigo USMC
454 oil pan Gasket.
