Author Topic: wiring question  (Read 6470 times)
Offline thirstycanadian
wiring question
« on: August 15, 2006, 04:01:00 pm »
Here's an old-school question for you all.  I am replacing my stock AM radio (1985 Sierra K35) with the oldest Alpine tape deck ever.  The Alpine is brilliantly labeled, but I cannot trace the stock wires back far enough to identify them.  Two go to the speaker (a grey and a tan)  which is positive and which negative?  Aside from the antenna there are three more wires (black, grey and yellow) which i assume are a 12V, a ground and one to the ignition.  Is that correct, and if so which is which?
Any help would be great. Thanks.
Re: wiring question
« Reply #1 on: August 15, 2006, 09:42:00 pm »
Best bet is either find a schematic or just use a meter.
Offline toplessblazer
Re: wiring question
« Reply #2 on: August 15, 2006, 11:33:00 pm »
Black is ground
Yellow is ignition
Grey is illumination that turns on with the parking lights
The original AM radio did not require a constant 12v supply. You can splice into the cig lighter wire (usually orange) for a constant.
