Author Topic: tie rod issue  (Read 5405 times)
Offline Buddy
tie rod issue
« on: May 06, 2011, 01:33:54 pm »
Ok I pretty sure I already know the answer but just to be sure here is my problem. i just installed new tie rods on my truck , 85 4x4 axl is a 78 1st design. My tie rods ends are super close on the ends one side is even hitting the rim. Is this just a matter of turning the adjustment in a little more. i know i have to get a alignment after i have done all of this. Right now i still trying to get the rebuild done and driveable enough to get it to the station.
Offline rwhit57
Re: tie rod issue
« Reply #1 on: May 06, 2011, 02:16:33 pm »
Buddy I know nothing about 4WD trucks, but I have ran into that issue on my 2WD. It seems as though some of the new tierods are bigger castings than others. The last set I bought I had to take a die grinder and clean them up a bit to clear the wheels. There's a lot of meat there you can remove safely. Hope this helps.
Randy from Okla
Whoever said "Money can't buy happiness" has obviously never seen a speed shop!
Re: tie rod issue
« Reply #2 on: May 07, 2011, 12:26:59 pm »
I dunno what your talking about, maybe because i dont have a 1st design. take a pic. my tie rods are connected to the knuckle.
Re: tie rod issue
« Reply #3 on: May 07, 2011, 01:16:32 pm »
hitting the tire?? the first style has a long divers side almost reaches the passengers side then a adjustment sleeve then a smaller tie rid almost the size of the 2nd or 3rd style
Offline Buddy
Re: tie rod issue
« Reply #4 on: May 07, 2011, 01:19:50 pm »
Yep! Hitting the rim.The pass side is rubbing. I noticed the lifetime warranty ones are much bigger. I guess I am going to have to go back to the cheap one as it is smaller
