Author Topic: New trailer wiring, fast blink turn signals  (Read 7873 times)
Offline zslates
« on: May 07, 2011, 04:53:57 pm »
I just got done wiring a 7 pin trailer connector and it all seems well until I hook up the trailer.. the turn signals flash much quicker.  Do I just need a new Heavy duty flasher?
Re: New trailer wiring, fast blink turn signals
« Reply #1 on: May 07, 2011, 05:34:35 pm »
HD Flasher should fix it up
« Reply #2 on: May 08, 2011, 12:06:46 am »
hd or electric flasher
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: May 08, 2011, 09:30:17 am »
i have a 7 pin connector on both my 79 pick up and 91 sub when pulling my 30' camper trailer.  Mine never had any problems.  I am wondering if you have a bulb out.  I do know that when a bulb is blown, the flash pattern speeds up drastically.  Any bulbs out on the trailer?
Offline zslates
« Reply #4 on: May 10, 2011, 11:41:33 pm »
I'm going to upgrade to the electrical/mechanical type ( vs thermal).  After learning about how thermal flashers work I'm pretty sure the increase in load is causing the symptoms.
« Reply #5 on: May 11, 2011, 08:59:13 am »
im thinking more like sgt now a blown bulb will cause rapid flash and the more bulbs should cause slower flash. are the trailer lights l.e.d.
« Reply #6 on: May 11, 2011, 10:07:28 pm »
That is correct. Less lighting means more juice going to flasher, making it faster. Even if the trailer lights are LED, they are drawing off the same circuit.
