Author Topic: Gas Gauge past full  (Read 5228 times)
Offline benzesrule
Gas Gauge past full
« on: May 10, 2011, 04:33:51 pm »
Hi, I have a 84 K10 with dual tanks and the gas gauge is past full at the 3 oclock position( right tank) and on the full mark on the left tank. I found a broken ground wire behind the gauge cluster and fixed it.  I even ran a new wire replacing the pink wire from the selector valve to the cluster and the gauge stayed the same. I replaced the fuel gauge with one that I had laying around, stayed the same. I noticed someone has replaced the left tank and it is a 20 gallon while the right tank is a 16 gallon. I use the right tank most of the time. This truck had 16 gallon tanks from the factory. The selector valve is operable. Both tanks are grounded. Any suggestions?
Re: Gas Gauge past full
« Reply #1 on: May 10, 2011, 04:38:00 pm »
A dirty switch will cause that problem, been there.... Just fixed my switch on my 85 last night, did that same thing..
Offline 87454westernhauler
« Reply #2 on: May 10, 2011, 06:08:05 pm »
My 87 had a very similar problem with the switch.
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline benzesrule
« Reply #3 on: May 10, 2011, 08:46:45 pm »
It has a brand new switch for the fuel selector.
Offline 1979C20
  • Kyle Taulton.
« Reply #4 on: May 11, 2011, 11:03:41 am »
Kind of related, how in gods name do you remove the switch from the dash?
Offline DnStClr
« Reply #5 on: May 11, 2011, 05:59:00 pm »
Twist the switch gently to the left and right. It should come loose. Then wiggle it up and down as you remove it. Don't get too gorilla- like with it. Some finesse is needed..
Don
87 Chevy Silverado
