Author Topic: Radio trim kit  (Read 9961 times)
Radio trim kit
« on: August 29, 2006, 07:28:00 pm »
Offline pcmcobra
Re: Radio trim kit
« Reply #1 on: August 30, 2006, 07:25:00 pm »
I'm actually putting that kit in my truck on friday. I'll take some pics of the completed project.
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
metra kit
« Reply #2 on: August 30, 2006, 10:20:00 pm »
I used that exact kit in my 74, and it was a lifesaver. My dad thought I was going to RotoZip my dash to death, but the metal plate works really good with a permanent marker to make a template. Make sure that you are extremely careful with how you cut the plastic bezel, though. Mine cracked and burned when I tried it with the RotoZip. I still haven't figured out what the best way to cut that thing with would be. It would have to be low-heat and sharp as heck, like one of those car model cutting knives (zacto blades, i think they're called).
-Mike
Offline Redneckchevy
    • Photo Bucket
dremal
« Reply #3 on: September 01, 2006, 09:49:00 pm »
i used a dremal with the small cut off wheel... use it at a low rpm so u dont melt the bezel
Re: dremal
« Reply #4 on: September 02, 2006, 09:28:00 am »
I just cut mine with a hot knife. I bought it at Lowes for like 14 bucks and it comes with a soldering iron. It worked beautiful! I'll post pics later
www.lowes.com/lowes/lkn?action=productDetail&productId=123257-273-WSB25HK&lpage=none
    • Photo Bucket
kool
« Reply #5 on: September 02, 2006, 11:01:00 pm »
i like that...u have more control over it...somthing a novice should look at ...a high speed dremal loves to take off on ya....
Offline woodys86sw
Re: kool
« Reply #6 on: February 05, 2007, 03:24:00 pm »
The dremal is the way to go and as said "at a lower speed".:)
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: kool
« Reply #7 on: February 05, 2007, 08:40:00 pm »
Just take a 4 1/2" grinder and cut the metal under the plastic.  Then take a soldering gun (with flat blade) and melt the plastic to fit the rectangular shape of the newer stereos. It took me about an hour to do this....
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
