Author Topic: I'm stumped!!  (Read 7436 times)
Offline 1978 K20
I'm stumped!!
« on: May 16, 2011, 01:45:14 am »
So here is the deal.
I've got a 78 K20, The right brake light is having problems. First thing I did is changed the bulb (twice) and still nothing. The weird part is that there is power to the socket. It is a 1157, so it is dual filament. When only the tail light is only on there is power to one side, and when I press the brake pedal there is power to both sides (like there should be.) BUT THE LIGHT STILL ISNT WORKING!
It wasn't working last night, yet it worked when I left work, and didnt work when I backed into my driveway (2ish miles away.)
ANY ideas are welcome. Thanks!
-John
1978 K20 "Custom Deluxe"
Dana 44 (locked), SBC 350, SM465, NP205, 14 Bolt
Lifted Six (ish) inches, Sitting on 35x12.5x16.5 BFG A/T
Warn 8274 Winch
Dual whip CB
In the works: Ladder bars, MSD, and other goodies
Re: I'm stumped!!
« Reply #1 on: May 16, 2011, 10:02:57 am »
bad ground
Offline 1978 K20
Re: I'm stumped!!
« Reply #2 on: May 16, 2011, 10:36:30 am »
But where is a ground in that circut?
Warn 8274 Winch
Dual whip CB
Re: I'm stumped!!
« Reply #3 on: May 16, 2011, 05:02:19 pm »
Re: I'm stumped!!
« Reply #5 on: May 16, 2011, 09:28:13 pm »
could also be a bad socket
Offline 1978 K20
Re: I'm stumped!!
« Reply #6 on: May 17, 2011, 12:18:46 pm »
Unless I have gotten two bad sockets in a row, I am ruling out a bad socket. I think my best bet is going to be to shoot wiring and try to find a bad ground.
Warn 8274 Winch
Dual whip CB
Re: I'm stumped!!
« Reply #7 on: May 17, 2011, 06:38:46 pm »
did you change the bulbs and sockets or just the bulbs
Re: I'm stumped!!
« Reply #8 on: May 17, 2011, 06:57:25 pm »
If you think its a bad ground runa jumper wire from the the housing to a good ground and see if it works.
Offline fitz
Re: I'm stumped!!
« Reply #9 on: May 17, 2011, 08:19:58 pm »
You can count on Vile for a solid answer. I would have said to run the jumpers into the left brake light and call it a day.
