Author Topic: Sottering Cab Repair kit???  (Read 8169 times)
Offline 87454westernhauler
« on: May 17, 2011, 02:47:57 pm »
Probably a dumb idea but I have been thinking about replacing the floor pan, cab corner and rockers on my 80 1/2 ton. the only problem with doing that is that I do not have a welder. my question it, could I just sotter the new cab part in or would that be a very bad idea??
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline 4x4orbust
Re: Sottering Cab Repair kit???
« Reply #1 on: May 17, 2011, 03:21:59 pm »
it's "solder" not sotter.....    sorry, i'm a spelling nazi sometimes.
i don't think it would hold for very long, but i have never tried it.   if you are doing it temporarily untill you get a welder, rivet the patches in.
« Reply #2 on: May 18, 2011, 12:08:46 am »
Its won't hold. If anything you can braze the patches in. Before welders thats how all body work was done.
Offline slammed79
  • Thou shalt not drive stock
« Reply #3 on: May 18, 2011, 12:13:19 am »
The Solder won't hold, as stated. There is of course riviting, and once I jb welded some shaved door handle fillers in. I think they're still in the truck, but I haven't seen it in a while
Praise the lowered
Offline ssapach
« Reply #4 on: May 18, 2011, 08:56:17 am »
x2 on the brazing.  Brazing can actually be very strong and bonds to lots of metals and will join different base metals....even dirty metal (to an extent).
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #5 on: May 18, 2011, 11:37:15 am »
I knew an old man back in Alabama who could braze floor pans back in using coat hangers. He did a car for me once and it turned out great.
Offline ssapach
« Reply #6 on: May 18, 2011, 02:58:30 pm »
not actually brazing if it was coat hangers, but rather plain old oxy-acetylene welding (or another fuel gas welding).  You can practically use anything that is steel for oxy-acet welding.  Things like coat hangers, nails, barbed wire......its not all made for filler metal, but it definately works in a pinch
Just for the record, proper filler rods have additives and deoxidizers and such, allowing cleaner and stronger welds.  But like I said, in a pinch almost anything will work.
« Reply #7 on: May 18, 2011, 03:37:55 pm »
ya but I dont think that when welding body parts, you should do something "in a pinch" IMO
Offline PromiseKeeper
« Reply #8 on: May 18, 2011, 06:10:34 pm »
I see where the body shop supply places are selling an epoxy that actually glues the metal in. I hear it does a good job and of course no warping.
1980 C-10 2WD short & wide. 305 auto.
« Reply #9 on: May 18, 2011, 07:42:37 pm »
You'd be better off with panel bond adhesive but as the old saying goes, do it right the first time. Save up for a welder or bring it to a body shop.
Offline tsroark
« Reply #10 on: May 20, 2011, 05:06:26 am »
I have been debating mentally weather I should find a replacement cab for my truck or just get a repair kit.  I personally don't have a welder but can borrow an arc welder, but would have to practice a bit with the welding.
Riviting was mentioned above.  I can do that, but would i just be able to cut out the bad spots and rivit in new floorboards, rockers, corners, floor supports?  Would the panels line up or would the cab warp a bit due to the overlap?
Thanks
80 Chevy k20 Bonanza, 350 w/ quadrajet, TH400, Np205, GM 14 bolt rear, d44 front.
