Author Topic: big block ponys! i need more!!!  (Read 5564 times)
Offline 84scottsdale454
« on: May 20, 2011, 12:23:31 pm »
i finally figured out what 454 was in my 84 c10! its an LF-8 250hp motor that was made in 76-80! The only performance parts i have on it now are exhaust,headers,k&n,and an edelbrock intake and 600 carb! what should i do next? i really want 400hp without changing the bottom end, what a safe number without changing the bottom end? it is my weekend driver!!
Offline topp
Re: big block ponys! i need more!!!
« Reply #1 on: May 20, 2011, 12:40:08 pm »
What you want is a good balance of Torque and HP.
Torque gets you going off the line, HP takes over after that.
'90 Suburban TBI 350
Offline screamin86
« Reply #2 on: May 20, 2011, 12:44:32 pm »
talk to some cam companys and get a cam picked out that will get you close.
86 ta:lm7 hot cam boltons
Offline Grim 82
« Reply #3 on: May 20, 2011, 01:01:11 pm »
Heads & a cam.
« Reply #4 on: May 20, 2011, 03:56:57 pm »
i was thinkin of just having a cam installed! i have no idea of any1 around here who can do it though so im sure ill have to go out of town! would having a set of aluminum edelbrock heads be better than a cam? if i was to pick on of the two which would it be? what if i had my stock heads worked??? ive seen top end kits for sale but im thinkin it may be too much hp and torq for my stock bottom end!
Offline screamin86
« Reply #5 on: May 20, 2011, 04:21:53 pm »
Cam swaps are pretty easy you should be able to do it yourself in about a day. Head will help a lot too but to get the full benifit a cam will help.
Offline Edahall
« Reply #6 on: May 20, 2011, 05:15:43 pm »
The heads that you've got were designed for good low rpm torque for pulling a large load but are a major road block for developing high HP numbers.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
« Reply #7 on: May 20, 2011, 05:24:50 pm »
« Reply #8 on: May 20, 2011, 06:29:00 pm »
Suppose if I bought a top end kit from edelbrock and installed it,will my bottom end support that kind of power?
