Author Topic: Question on Valvetrain  (Read 4371 times)
Offline Da67goatman
  • Burban
« on: May 31, 2011, 07:04:47 pm »
What is factory rocker ratio on smallblock 350?  What are stock valvesprings max lift?  Thanks to whoever can answer.
<Pitcrew>
Offline Psycho71
Re: Question on Valvetrain
« Reply #1 on: May 31, 2011, 08:16:08 pm »
Stock rocker arm ratio would be 1.5:1... Not sure about the max lift of the springs, but I've seen people run .450" lift cams with stock valve springs before. Not sure if they were right in doing so, but no major failures occurred.
Offline Da67goatman
  • Burban
« Reply #2 on: June 01, 2011, 08:27:08 am »
I have come across a cheap set of 1.7 rockers, can I run those with a stock cam for better performance without lose of mileage?  Would that be too much lift for stock springs?
<Pitcrew>
