Author Topic: quick question  (Read 6027 times)
Offline BIG CHEVY
  • FOLLOW ME,,,, ILL TRY IT.
quick question
« on: June 04, 2011, 10:16:58 pm »
took out my locking hubs today.   they did not have a small snap ring like others i have done. did have an outer ring but no small axle end sized ring. also my axle does not have a groove for this ring. can anyone tell me why my situation is different? also should i be running without the little snap ring?
Re: quick question
« Reply #1 on: June 05, 2011, 02:32:04 am »
cant help. never seen one with out. what axle do you have? any pics?
Re: quick question
« Reply #2 on: June 05, 2011, 07:07:43 am »
Don't have an answer as to why, but I have seen many that don't have that inner ring. Ive even taken trucks apart that one side has it, and the other side doesn't!
Offline BIG CHEVY
Re: quick question
« Reply #3 on: June 05, 2011, 10:29:47 am »
Plenty good enough for me. Cant figure out pics without photobucket. Trying. But i have an even better question. How do u get the bearing inside the spindle out?
Offline Grim 82
Re: quick question
« Reply #4 on: June 05, 2011, 03:52:27 pm »
You need to remove the rear hub seal to remove the inner wheel bearing.
Re: quick question
« Reply #5 on: June 05, 2011, 11:42:19 pm »
I use a slide hammer with a hook attachment on it, or and oval punch through from the outside end.
