Author Topic: Gas pedal stiff on TBI  (Read 13104 times)
Offline chevytruknut
« on: June 21, 2011, 12:04:44 pm »
Hey guys, I have an 87 silverado with a 350 tbi eng. and 700R trans.  My gas pedal is hard to push. I've tried two different tbi units and the last one I rebuilt. I have a brand new throttle cable and the trans cable is adjusted correctly. Am I missing something? I've had other TBI trucks and the gas pedal was normal. I am doiing jackrabbit starts every time I take off. Anyone else have this problem?
Re: Gas pedal stiff on TBI
« Reply #1 on: June 21, 2011, 10:09:23 pm »
Nope. Is the cable binding?
« Reply #2 on: June 22, 2011, 10:17:21 am »
Nope, new cable
Offline 1979C20
  • Kyle Taulton.
« Reply #3 on: June 22, 2011, 10:45:32 am »
It could still be binding. Did you lube the sleve around the cable that comes out of the firewall?
Offline Grim 82
« Reply #4 on: June 22, 2011, 10:49:22 am »
Disconnect the cables and turn it by hand. Hook up one cable at a time and see which one is giving resistance.
Offline topp
« Reply #5 on: June 22, 2011, 12:17:03 pm »
Check the pedal in the truck....
Unhook cable and see if the pedal is binding...
'90 Suburban TBI 350
« Reply #6 on: June 22, 2011, 01:27:18 pm »
Do you have a return spring hooked to it?
« Reply #7 on: June 25, 2011, 06:33:27 pm »
Thanks for the help. Soon as I figure this out I'll post the fix.
Offline 1979C20
  • Kyle Taulton.
« Reply #8 on: June 25, 2011, 06:42:37 pm »
How stiff is your throttle return spring? That could be a culprit as well.
« Reply #9 on: June 27, 2011, 03:26:00 pm »
If you have a spring on a TBI THAT is the problem.  The return spring is built into the Throttle body.
Offline 1979C20
  • Kyle Taulton.
« Reply #10 on: June 27, 2011, 04:31:17 pm »
i didnt know that capt. Pretty interesting. I figured that when you asked if it had one that it was supposed to.
« Reply #11 on: June 27, 2011, 10:00:19 pm »
post a pic of what you have
