Author Topic: Brake booster  (Read 5243 times)
Offline 84chevysilverado
Brake booster
« on: July 05, 2011, 06:57:09 am »
My brake booster has a leak everytime I hit the brakes you can hear the the booster lose vacume. My question is will an 88 chevy truck or newr booster work on mt 81 k5?
Re: Brake booster
« Reply #1 on: July 05, 2011, 11:11:26 am »
Don't think so due to yours being a MT. I took gasket sealer and put alot between the master cylinder and booster. Fixed the leak lol
Offline topp
Re: Brake booster
« Reply #2 on: July 05, 2011, 11:44:18 am »
Theres a death trap waiting to happen....
'90 Suburban TBI 350
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Brake booster
« Reply #3 on: July 05, 2011, 11:57:32 am »
There are tests to see if the booster is bad.  One is, do you have to nearly stand on your pedal to get the brakes to work?  Should hear a whoooshing sound too when applying brakes.
 check this thread out....
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5202.0
Re: Brake booster
« Reply #4 on: July 05, 2011, 01:50:31 pm »
lol na its all good no leaks and most time i dont even use them i just down shift.
Re: Brake booster
« Reply #5 on: July 05, 2011, 02:12:04 pm »
If your diaphragm is shot it's shot. Replace it. When you step on the pedal you should hear the sound of air pressure rushing in. If you hear a sustained suction sound when you depress the pedal replace the booster.
Re: Brake booster
« Reply #6 on: July 05, 2011, 08:15:34 pm »
yeah all joking aside replace it asap. the reason i did that to mine i couldnt keep her running to go mudding it was a cheap quick fix to have fun i dont even drive her anymore starting a resto
Offline Bitzer!
  • Smiles per gallon
Re: Brake booster
« Reply #7 on: July 08, 2011, 04:02:08 pm »
I bit the bullet recently. Started to clean my old unit and it was leaking like a sieve. Just ordered a nice shiny unit to bolt straight on!!
1979 GMC CrewCab  C20 1t
