Author Topic: th350 to 700r4  (Read 8429 times)
Offline bigblock73
  • Yeller
th350 to 700r4
« on: September 28, 2001, 11:55:00 am »
Does anyone or has anyone done this swap?  I am going to put in an overdrive trans (haven't purchased it yet) in place of the th350 in my '73 2WD and was wondering if I need to purchase a crossmember from an overdrive equipped truck or can I just reposition mine and drill new holes in the frame?
Jeff
'73 swb 2wd
73-87.com
Offline bigblock73
  • Yeller
Re: th350 to 700r4
« Reply #1 on: September 28, 2001, 12:03:00 pm »
whoops, wrong section.  I can't figure out how to move it so I'll re-post it to the general section.
Jeff
'73 swb 2wd
73-87.com
Offline blazer1961
Re: th350 to 700r4
« Reply #2 on: February 03, 2003, 03:08:00 pm »
should bolt right in.
Offline abig84
swap
« Reply #3 on: May 06, 2003, 06:20:00 pm »
the 700r4 is a bit longer then the th350 so you may have driveshaft problems and if it was a 4x4 the adapter between the transfercase and trans would be different
Offline 73K20
Re: swap
« Reply #4 on: May 07, 2003, 07:03:00 am »
The adapters are the same between the tranny and t-case.  Both the TH350 and the 700R4 have 27 spline output shafts so there is no problem there either.  I think that you should be able to get by in using your old driveshafts too.
1973 K20 - 350/350/205
