Author Topic: Ever wired up an electric gauge?  (Read 5001 times)
Offline Skunksmash
« on: July 14, 2011, 11:32:18 pm »
Hi all. I recently bought a digital water temp gauge. My factory gauge sucked too much. It would say the truck was running at 155 when my code reader would say it was running at 183. I blame it on a factory gauge that probably wasn't great back in 1987. Let alone now. So anyway, where do I tie into for power? Just any old hot wire? Or do I need to run this all the way to the battery? I'm kind new at wiring up my own stuff.
Offline Bitzer!
  • Smiles per gallon
Re: Ever wired up an electric gauge?
« Reply #1 on: July 15, 2011, 03:33:56 am »
 Hi bud, I'd run the feed from the temp sender to gauge, power feed from ignition so any live when the key is on click one and then earth/ground it
Pretty basic really
1979 GMC CrewCab  C20 1t
« Reply #2 on: July 18, 2011, 07:03:45 pm »
yup.
Offline Skunksmash
« Reply #3 on: July 25, 2011, 03:48:44 am »
Probly a dumb question, but is there any need to run the new sensor and wire? Is there any reason I shouldn't just use the old one? I replaced that actual sensor itself a year ago.
Offline 1979C20
  • Kyle Taulton.
« Reply #4 on: July 25, 2011, 04:12:29 am »
Most of the time the sensor/sending unit is what goes bad. Ive had to replace my Mechanical temp gauge 3 times already because of the sending unit going out and it not showing the temp.
