Interior & Equipment
Steering Columns
sloppy steering
Topic: sloppy steering (Read 9985 times)
str8bloc
MISTRESS
sloppy steering
July 21, 2011, 08:24:43 am »
well i got down to the inverted torx and the hub, as i call it is loose. is there something its missing or what
FaTbOy
beastie_3
Josh
Re: sloppy steering
July 21, 2011, 11:53:18 am »
what?
Semper Fi
1979C20
Kyle Taulton.
Re: sloppy steering
July 21, 2011, 04:34:14 pm »
Quote from: beastie_3 on July 21, 2011, 11:53:18 am
what?
x2
str8bloc
MISTRESS
Re: sloppy steering
July 21, 2011, 09:47:53 pm »
well my steering column is loose so i followed the instructions to take it off i got to where the common problem is i was wondering the shaft that holds the steering wheel is loose i can see into the column is something missing
FaTbOy
1979C20
Kyle Taulton.
Re: sloppy steering
July 22, 2011, 03:28:10 am »
So, you can see around the inner shaft in the column and your steering wheel is sloppy? I havent taken apart a column yet, so I cant help you, but is that what you are saying?
str8bloc
MISTRESS
Re: sloppy steering
July 22, 2011, 10:19:43 am »
thats correct i retightened the torx so well see how it goes
FaTbOy
beastie_3
Josh
Re: sloppy steering
July 22, 2011, 12:29:57 pm »
hope you used locktite on the screws.
is this what you did?
http://forum.73-87chevytrucks.com/smforum/index.php?topic=12525.0
you took the whole steering column off? when you say your steering wheel is sloppy, do you mean when you turn the wheel, or do you mean up and down and left and right?
got to lay of the hooch when typing on a computer!
Semper Fi
str8bloc
MISTRESS
Re: sloppy steering
July 22, 2011, 01:27:23 pm »
sorry been a long mornin. upper steering shaft bearing retainer and race. is the race pressed in? i think i need a new retainer mine is screwed ip bad! thats probably my problem.gonna go to a junkyard and pull some parts
FaTbOy
str8bloc
MISTRESS
Re: sloppy steering
July 23, 2011, 11:18:06 am »
it was the race and retainer. fixed it, nice and tight now
FaTbOy
Steering Columns
sloppy steering
