Engine/Drivetrain
th400 kickdown switch
Topic: th400 kickdown switch (Read 11582 times)
bigchevyc30
the pig
July 27, 2011, 11:57:10 am »
OK so i have found a switch right in front of the top piece on my gas pedal since i just learned about the kickdown switch now are the images i have the switch i think the P.O. put the piece of hose on it
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
devanray
Re: th400 kickdown switch
July 27, 2011, 04:50:52 pm »
thats it. Not sure what the hose is for though. Just make sure its plugged into a siliniod (sp?) on the drivers side of the tranny. Floor it while your driving and you should feel it kick down a gear.
"Before removing any bolts, read through the entire procedure."
bobcooter
1979 Scottsdale C-20
July 27, 2011, 08:53:07 pm »
I think hose is some type of homemade adjustment. Doesn't the gas peddle rod strike it from the side.The hose would basically shim it up some to where the gas peddle doesn't have to travel quite so far???
Dr_Snooz
"I like to take hammers, and just break stuff"
July 27, 2011, 09:13:29 pm »
Yes! Thanks for asking this question. I've been laboring under the assumption that the kickdown was wired to the stock carb that I swapped out some time ago. I need to reconnect my kickdown switch!
bigchevyc30
the pig
hooked up the kickdown
August 06, 2011, 09:11:54 am »
well today since it was pretty cool out i hooked up my trucks kickdown solinoid to the switch and man did it make a big difference for acceleration in my dually. thanks for the people that helped me find out it neded hooked up
big bear
Re: hooked up the kickdown
August 06, 2011, 09:18:08 am »
glad that worked out
Engine/Drivetrain
