Author Topic: Un-attached Wire  (Read 6980 times)
Offline pedigo78
  • Big Blue
Un-attached Wire
« on: August 01, 2011, 07:13:24 pm »
So I was under my dash of my 85 and I noticed a brown wire with a white stripe which still has the correct connector on it but not attached it anything. I noticed it under the dash close to the parking brake lever. Anyclue as to what it is and where I should connect it. Also I have a post on here about the horn relay and how i cant found it, i had some pictures but that didnt help me either.
Sgt Pedigo USMC
Re: Un-attached Wire
« Reply #1 on: August 02, 2011, 12:24:23 pm »
If it is actually a black wire with white stripe, then its a ground and there is a prong on the e brake bracket that it goes on. brown with white stripe is seatbelt light i think.
Offline pedigo78
  • Big Blue
« Reply #2 on: August 02, 2011, 05:51:10 pm »
I will take a look, my seatbelt lights comes on. Thanks
Sgt Pedigo USMC
Offline 1980c10
« Reply #3 on: August 02, 2011, 06:24:05 pm »
Park brake light maybe?
Offline pedigo78
  • Big Blue
« Reply #4 on: August 02, 2011, 06:27:15 pm »
Maybe I did notice some prongs on the brake, of course there is nothing plugged into them. But I dont know. heck I am still trying to find my horn relay in order to see if that is the problem with that not working.
Sgt Pedigo USMC
« Reply #5 on: August 03, 2011, 03:21:23 pm »
There should be 6 prongs, those are to ground to. The e brake wire is separate.
Offline pedigo78
  • Big Blue
« Reply #6 on: August 03, 2011, 04:09:40 pm »
all heck i dont know anymore
Sgt Pedigo USMC
« Reply #7 on: August 03, 2011, 04:36:11 pm »
This shows the 6 ground points
This shows the parking brake switch, which illuminates your parking brake light. It is the white plastic piece in the back with the hex screw. I had to remove the flasher to take the pic.
Offline pedigo78
  • Big Blue
« Reply #8 on: August 03, 2011, 07:12:23 pm »
Thanks, appreciate the picture sorry if it was any trouble.
Sgt Pedigo USMC
Offline pedigo78
  • Big Blue
« Reply #9 on: August 03, 2011, 08:18:29 pm »
ok here are some bad pics i took. This shows the wire from the harness, it is brown with a white stripe and a single connector on it.
Sgt Pedigo USMC
