Author Topic: ignition cylinder  (Read 5221 times)
Offline 84chevysilverado
ignition cylinder
« on: August 04, 2011, 09:33:31 pm »
Last weekend I lost my keys while swimming :'(. I bought a new ignition cylinder yesterday but cant figure out how to get the old one out. I no that with most gm's you turn the ignition switch to acc and push a tab and the cylinder pulls out. since i dont have a key im puzzzled any ideas?
Offline 1979C20
  • Kyle Taulton.
Re: ignition cylinder
« Reply #1 on: August 04, 2011, 09:46:59 pm »
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: August 05, 2011, 12:25:18 pm »
wow, looks complicated.  Too bad you didn't have an extra set.
« Reply #3 on: August 06, 2011, 07:18:54 am »
You can skip steps 23 -30, and all the one past removing the lock cylinder. This write up is for fixing a sloppy tile column.
Granted I have done a quite a few of these over the years, but I can do them in about half hour. Biggest thing is remembering where everything goes. Snap a some pics as you go, or use these as a guide you should be good.
« Last Edit: August 06, 2011, 07:26:51 am by Blazin »
Offline 1980c10
« Reply #4 on: August 07, 2011, 02:09:29 am »
You could check with a locksmith to see if they can make a key or check with the local gm dealer to see if they can make a key from the vin. I had an issue with a copied key(my only key) working poorly and they were able to make a new key from the vin alone, however, it was a 10 year old car so who knows.
« Reply #5 on: August 07, 2011, 08:27:27 am »
I deal with a GM dealer on a regular basis at work, When ever its something I'm looking for on one of my trucks they always say its to old for VIN number identify.
Offline jaredts
« Reply #6 on: August 07, 2011, 04:22:49 pm »
Try turning the ignition without the key.  It works on a lot of old gm's (in which case you still want to eventually replace it).
Offline Joe-NC
« Reply #7 on: August 17, 2011, 10:09:04 pm »
Funny you should mention this. My keys just fell out of the ignition while the truck was running yesterday. It kept running and I realized that I don't even need the key. One less thing to keep up with.
These trucks keep getting better with age!
