Author Topic: Don't be too cheap---what an exploding tire can do to the quarter panel:  (Read 32087 times)
Re: Don't be too cheap---what an exploding tire can do to the quarter panel:
« Reply #30 on: November 03, 2011, 06:53:26 am »
OK, scratch that last statement----it does work-----i apparently did not give it enough time to dry;  i had sprayed it at about 5pm yesterday and now it's all pretty much black.  So i guess it does work---even on "overhead" situations.
Will post pics asap
2) as far as the patch panel.  i have not made it up to the point where i can just cut out and weld in new metal.  i may very well go this route.
     Never doubted for a minute.  Like I said I use it a lot at work and as long as I use it for what it is intended, It never has let me down.  Glad to hear it worked for you.
Offline Stewart G Griffin
« Reply #31 on: November 03, 2011, 10:19:45 am »
Yes, it certainly seems to work.  By the way, and i'm not sure i'm allowed to post this here, but Gempler's the store has some pretty fast service.
Offline malibu795
« Reply #32 on: November 04, 2011, 06:34:35 pm »
blow outs stink!
i got lucky had 34000lb on those tandems.
adam wildman
75 K25 383/400
« Reply #33 on: November 05, 2011, 11:55:52 am »
Recap?
Offline velojym
« Reply #34 on: November 08, 2011, 07:35:21 am »
Sometimes, but not always. Virgin rubber is assembled too, and I've had tread separation on them as well. Retreads are a heck of a lot better now than they used to be. (Note: not a salesman....)   ;)
Offline malibu795
« Reply #35 on: November 10, 2011, 09:02:05 pm »
yeah cap had 190 miles on it when it peeled. replaced cab has 9k on it already
adam wildman
75 K25 383/400
Offline gto109
« Reply #36 on: November 13, 2011, 06:34:02 pm »
Malibu i had a tire blow in the same spot on a kenworth t2000 i drove a while back and it took out my catwalk.  When i got the truck from the company it was on all new virgin rubber.  i think it had 15k miles when it blue but we ran the trucks as close to 40 ton as possible.
85 Scottsdale k-10 305 700r4,
86 Trans Am 305 350th
06 Dodge Ram daily driver
Offline gildardo01
Definately glad you're ok. Tires are something I don't mess with. Only cheap tires I buy go on vehicles that wont see the street. Just for rollers around the property. I hate having to change flats or even air up tires that go flat after a few days. The last set of tires I bought for my work truck were over $1200. I buy 10 ply because the oilfeild roads I drive on will destroy a weak tire. I was asked why I bought the high dollar tires all the time. My answer is simple. A $200+ tire is cheaper than a body repair shop.
  You may be able to bend it back out and straighten it out with a hammer and dolley, but its gonna take time and patience.Good luck too ya
same thing i say... i don“t like buying cheap tires... they loose air and tend to get more flats than a name brand tire... and breaking and handling is a whole different level when it comes to name brand tires...
Offline popsthebuilder
Just payed for two new front ones yesterday. Didn't get them put on today like I was supposed to. We were both busy. Tires that came on truck are over twelve years old but have nearly all tread. I guess the truck sat parked for a  decade or so. Glad mine are waiting on me. I don't want to think what might happen to my truck if one of the front tires blew out. Would flip that big...pickup  before I hit someone else though.
