Author Topic: Bed Rattles  (Read 13969 times)
Offline bladerunner
Bed Rattles
« on: September 01, 2011, 07:25:53 pm »
Hey everyone-
So the truck is all inspected and I have been driving it back and forth to work all week, loving it!
One thing however is the bed has a pretty significant rattle to it.  The bed is new and was installed maybe a year ago by the PO.  My father-in-law believes the noise (which is pretty annoying on rough Maine roads) is due to the fact that there is no padding (or some other absorbing material) where the bed meets the frame.  He suggested I spray some expandable foam in between the gaps. I'm not sure about that.  What do you guys think?
85 K10 Shortbed
94 Impala SS
Offline muddpuppy01
Re: Bed Rattles
« Reply #1 on: September 01, 2011, 07:47:58 pm »
I would check to make sure you have bushings in the mounting spots and check to make the bolts have not back off some
Re: Bed Rattles
« Reply #2 on: September 01, 2011, 09:16:04 pm »
Yeah, no.
Is this a rattle over bumps? Is the converter heat shield loose? Common problem.
Re: Bed Rattles
« Reply #3 on: September 01, 2011, 11:38:52 pm »
     Why are there gaps between the bed and frame ?  If the bed is loose it will bounce, but I am with Vile, the more common problem is the heat shield.
Offline thirsty
    • Suitor's Garage
Re: Bed Rattles
« Reply #4 on: September 02, 2011, 07:01:02 am »
Did you check to see if it is coming from the tailgate? I wouldn't use spray foam, it will hold moisture and rot what it is on.
Offline SNWBLL
Re: Bed Rattles
« Reply #5 on: September 02, 2011, 08:46:16 am »
My bed rattle was due to loose shocks. I tightened them up and no more rattle.
I do have a bit of squeeking in the suspension when going thru odd dips and turns.
Mike
85 longbed
86 shortbed
Offline bladerunner
Re: Bed Rattles
« Reply #6 on: September 02, 2011, 01:59:05 pm »
Exactly my thought.
I have tried to isolate the noise and am fairly certain it is the bed. Its one of those situations where multiple sets of ears would be real handy.  I expect a fair bit of road noise in an old truck, but this is something else.  Looks like I will first check the bushings and the shocks. I'll keep everyone posted and thanks again!
85 K10 Shortbed
94 Impala SS
Re: Bed Rattles
« Reply #7 on: September 02, 2011, 02:00:41 pm »
Shake the bed and bounce on the bumper.
Offline bladerunner
Re: Bed Rattles
« Reply #8 on: September 02, 2011, 06:06:30 pm »
This is what I meant by gaps:
85 K10 Shortbed
94 Impala SS
Offline bigchevyc30
  • the pig
Re: Bed Rattles
« Reply #9 on: September 03, 2011, 12:22:05 am »
i would think those gaps are normal since the bed has the ridges
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Re: Bed Rattles
« Reply #10 on: September 03, 2011, 01:13:53 am »
Easy enough to tell if its them. Take a hammer and bang on them some, Se if you get the rattle?
Offline bladerunner
Re: Bed Rattles
« Reply #11 on: September 03, 2011, 06:40:05 am »
Yeah, they're normal, my father-in-law wanted me to spray foam in them to cushion the bed, which seems silly to me.
85 K10 Shortbed
94 Impala SS
Offline bobcooter
  • 1979 Scottsdale C-20
Re: Bed Rattles
« Reply #12 on: September 03, 2011, 06:45:32 am »
If it's squeaking from the rear your shocks may be damaged.  Get someone to stand in the bed and bounce up and down while you get on the ground and listen closely. If it's from the front, grease your front end components and see if it goes away.
Offline bladerunner
Re: Bed Rattles
« Reply #13 on: September 28, 2011, 08:25:30 pm »
One thing I have noticed is that if it is cold out, say in the morning, there is no rattle. The rattles is only present when it is fairly warm, say mid 70s (which is warm for Maine).
85 K10 Shortbed
94 Impala SS
Re: Bed Rattles
« Reply #14 on: September 30, 2011, 09:46:10 am »
     I am sorry, but does this strike anybody else that in that picture, the cross member is welded to each section of bed.  Did you check like blazin said under your truck at each cross section to see if the welds are broken.  Heat causes metal to contract while cold expand, maybe it is that simple, you have a spot or couple that are cracked and when it is hot enough to contract they can move a little and bounce, metal on metal ?
