Author Topic: rt side fuel tank ???  (Read 3872 times)
Offline tigwelder
« on: September 02, 2011, 07:01:28 am »
eliminating rt side fuel tank.any thing i need to know about fuel line routing or anything else i need to change.
Offline muddpuppy01
Re: rt side fuel tank ???
« Reply #1 on: September 02, 2011, 07:13:10 am »
Belive that is the primary tank. So you would need to bypass the selector valve. That would get it to pull just from the left tank.
« Reply #2 on: September 02, 2011, 09:58:42 am »
     Just leave your selector valve on the left side.  Or remove the switch and selector valve and plumb only the left side tank like a single tank truck.
     Why are you removing a tank, why not just leave it in and run off the left if the right one has a problem ?
« Reply #3 on: September 02, 2011, 10:59:51 am »
Ya, I love having two tanks.
Offline Senck243
« Reply #4 on: September 02, 2011, 10:20:24 pm »
I am doing the same thing. I am eliminating the tank because the tank brackets rotted out and the tank and lines are bad. Only feel like putting up money for one.
1984 k10 305, sm465, np208
