Author Topic: windshield stains  (Read 9745 times)
Offline fuzz
windshield stains
« on: September 13, 2011, 08:30:05 am »
 Had a new windshield installed last year and after dirving for awhile it naturally got bugs splattered on it. I can't seem to get it clean. It's as if the windshield is poris and the stains are permanant.
 Anybody else have this problem? Do I need a better cleaner? Then maybe seal the glass with something?
The funniest thing about my signture is that before you realize it doesn't say anything it's too late to stop reading it!
Offline Da67goatman
  • Burban
Re: windshield stains
« Reply #1 on: September 13, 2011, 12:35:44 pm »
I use steel wool and it cleans EVERYTHING off your windows, bugs, wax, those windshield markers etc.
<Pitcrew>
Offline paniolo
« Reply #2 on: September 13, 2011, 04:42:16 pm »
If that doesn't work and you find it is minor scratches or water spotting, Cerium Oxide is a glass polish.  Comes as a powder, add a sm amt of water to make a paste, then using a low rpm drill/pad or buffer work it in the glass until clear and rinse with water.
David M.
Offline fuzz
« Reply #3 on: September 13, 2011, 07:44:15 pm »
 Did you mean plastic wool? Steel wool will scratch any windshield. I use a windshield scrubber from wal-mart on all my cars and it works great on all but the truck.
Offline silverj
« Reply #4 on: September 13, 2011, 08:25:54 pm »
Get a dryer sheet and wet it then scrub the bugs off with it works really well on baked on bugs and does not scratch, also leaves the truck smelling fresh and clean!!!
I do this with my motorcycles, keep them in the bag cause they stow away easy then just add water and presto a cleaning rag.
87 R20
« Reply #5 on: September 13, 2011, 10:43:16 pm »
Steel wool, triple 000 or finer. It won't scratch the glass.
Offline snibook7537
  • Vince Ziolkowski
« Reply #6 on: September 13, 2011, 11:31:56 pm »
I gotta agree with everyone on the steel wool, whenever I get a new (okay old) vehicle it's one of the first things I clean. I just use really good glass cleaner, the kind that comes in an aerosol can and steel wool.
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
« Reply #7 on: September 14, 2011, 01:01:37 am »
how does that work with the bug guts being on the outside of the truck? how can you smell the fabric sheet from the inside ::)
« Reply #8 on: September 14, 2011, 10:00:25 am »
     I would think my neighbor is a little off his rocker if I saw him sniffing his windshield in the morning.  :P  ???  ;D
Offline 756man
« Reply #9 on: September 14, 2011, 11:04:21 am »
Maybe he cleans the inside of the windshield with the fabric softner sheets too !
1985 Chevy K-20 longstepside, 350,Turbo 400
Offline 1979C20
  • Kyle Taulton.
« Reply #10 on: September 14, 2011, 12:23:00 pm »
One way that takes a bit more time is a razor blade. Get the window wet and then scrape the junk off. I do that when I get over spray on my windows. It comes right off. Just hold the flat side of the blade at a 45 degree angle to the window.
« Reply #11 on: September 14, 2011, 08:17:42 pm »
I have used single edge razor blades before as well.
« Reply #12 on: September 15, 2011, 10:20:23 am »
in my experience in blades you have to use the ones out of utility knifes so the flex to the curve of the glass
« Reply #13 on: September 15, 2011, 07:32:49 pm »
Single edge razor blades are what an inch long at best? How much curve does any glass have in a one inch span?
« Reply #14 on: September 15, 2011, 08:30:43 pm »
i must be thinking of a diffrent type then about 2.5" lol with the thick end. i cant remember what i was using one for but it wouldnt curve to the shape i needed had to steal one out of the box knife
