Author Topic: help with wires behind guages  (Read 8856 times)
Offline mrboyy17
« on: September 19, 2011, 05:10:20 pm »
hey guys i just put my guage panel back together and there are three lights i dont know where to put them in the circuit board?  one comes from over by the ash tray, the other two are in the wiring by the spedo cable and main harness for the circuit board.  the ash tray one is one wire.  the other two lights r two wires....brown and whit and pink w/brown stripe and white.  all of the other light bulbs r just twisty things i put behind the cirbuit board but i forgot where to hook these "wired" light sockets
any help?
mark
Re: help with wires behind guages
« Reply #1 on: September 19, 2011, 06:27:32 pm »
One is a 4x4 light I think
Offline paniolo
« Reply #2 on: September 20, 2011, 11:38:12 am »
Did you take the one that illuminates the wiper switch out?
David M.
Offline mrboyy17
« Reply #3 on: September 20, 2011, 08:06:40 pm »
here's some pics for you guys.  i need help knowing where to plug these lights in.  the first one is a wire that is coming off the top of the ash tray
the second one is brown and white wires going into a lamp receptacle
and the third is blue and pink wires going to a lamp receptacle..
i just need to know where to plug these into on the back.  my truck is a diesel so in the third pic you can see the glow plug light.  once i know where to plug these i can determine where to put all of the removable lights that twist into the circuit board.  thanks for any help
mark
Offline cvbear
« Reply #4 on: September 20, 2011, 08:35:39 pm »
Not sure what year you have.  On our '84 C10 Silverado SWB the light by the Ashtray goes to a socket that shines down on the floor when the interior lights are on.
Offline mrboyy17
« Reply #5 on: September 20, 2011, 09:07:48 pm »
ok there is already a light on the floor where the transfer case is.  ill look for a spot to plug that light in under the dash somewhere. thanks  its a 86 4x4 auto diesel by the way
mark
« Reply #6 on: September 20, 2011, 09:12:05 pm »
use the wiring diagrams on here in the tech section.
Offline DnStClr
« Reply #7 on: September 21, 2011, 08:58:52 am »
See if one of them goes to the Heater/AC assembly- gray and black wires.
See if another might go to the Low Coolant Warning light-the wiring schematic actually shows pink and gray wires.
Don
87 Chevy Silverado
Offline mrboyy17
« Reply #8 on: September 21, 2011, 03:38:28 pm »
thanks guys....ive been looking at that wiring schematic and it is like the instructions to put furniture together.  geeze i cant make heads or tails out of it.  what a joke anyway yea i see that the pink and grey one is probly for low coolant warning lamp.  still dont know about the white and brown one though
thanks for the replies
mark
« Reply #9 on: September 27, 2011, 07:30:07 pm »
What's up with the wire nuts and scotch locks? Do you have gauges or idiot lights?
