Author Topic: Anyone have a source for axle flanges?  (Read 4708 times)
« on: September 22, 2011, 09:09:31 pm »
Looking for brake mounting flanges that fit the 1/2 ton rear axles and not having much luck. It's a 3" tube with the 4 hole spaces approx 2.75" apart. Anyone have a source?
Offline HAULIN IT
Re: Anyone have a source for axle flanges?
« Reply #1 on: September 22, 2011, 09:24:55 pm »
What are you wanting to do...leave the original 12 bolt axle bearing "cup" & cut away the original plate & weld this "yet to be found" bracket on? What is the brake set-up for/from? I'm guessing this isn't the stock bolt spacing your after? Lorne
« Reply #2 on: September 23, 2011, 08:39:28 am »
Actually I am looking for the stock spacing on the exterior of the axle tube. Existing bearing cup set up. I'm playing around with a few ideas that will require killing the stock mount.
I see them for trailers http://store.rvdirect.com/rvdirect/details.php?ITEM=6511510
http://www.etrailer.com/comparison.aspx?pc=4-44-1&pc2=4-35
